    Installing USB Soundcard using seperate USB Mic
    12 Posts 3 Posters 8.0k Views 3 Watching
    • MrCoffeeM Offline
      MrCoffee @E3V3A
      @e3v3a
      Now it is getting weired.
      I disabled the internal broadcom by adding it to the blacklist:
      sudo tee /etc/modprobe.d/blacklist-snd_bcm2835.conf
      blacklist snd_bcm2835
      After reboot it is correctly not shown again:
      aplay -l
      **** Liste der Hardware-Geräte (PLAYBACK) ****
      Karte 0: Device_1 [USB Audio Device], Gerät 0: USB Audio [USB Audio]
        Sub-Geräte: 1/1
        Sub-Gerät #0: subdevice #0
      But if I start playing a media, the sound still comes from the audio jack.
      How can that be?
      • E Offline
        E3V3A
        dtparam=audio=off
        "Everything I do (here) is for free – altruism is the way!"
        MrCoffeeM 2 Replies Last reply Reply Quote 0
        • MrCoffeeM Offline
          MrCoffee @E3V3A
          @e3v3a
          Thanks for the help.
          I didn´t tried it yet because meanwhile my mic has some problems too. The “beep” from Alexa ist still there but sounds already not round. After that the mic does not react at all.
          Guess I will reset the whole system. Unfortunately I did not have a backup.
          By the way: If anybody of you knows a raspberry backup programm which I can use under windows please let me know.
          I will inform you when I reseted my system.
          • E Offline
            E3V3A
            @MrCoffee I don’t think resetting it is gonna be helpful, unless you know you have installed a bunch of other apt packages, and messed with system settings without writing down what you did.
            • E Offline
              E3V3A @MrCoffee
              @mrcoffee
              Try this: https://github.com/shivasiddharth/GassistPi/tree/master/audio-drivers/USB-MIC-JACK/scripts
              MrCoffeeM 1 Reply Last reply Reply Quote 0
              • MrCoffeeM Offline
                MrCoffee @E3V3A
                @E3V3A
                Hi, I tried the steps from “cloning” to "sudo /home/pi/GassistPi/audio-drivers/USB-MIC-JACK/scripts/usb-mic-onboard-jack.sh " (I have got Alexa not google assistant;-))
                The alexa beep sounds normal again, but after that there is silence. And I can still force the beep only once per reboot.
                • MrCoffeeM Offline
                  MrCoffee @E3V3A
                  @e3v3a said in Installing USB Soundcard using seperate USB Mic:
                  dtparam=audio=off
                  I just tried it. Unfortunately with no luck.
                  Sound still comes from the audio jack.
                  • MrCoffeeM Offline
                    MrCoffee
                    I reinstalled the whole system using another SD-card.
                    Now I can use the seperate USB-Mic and the audio Out comes from the other USB-Soundcard.
                    After that I installed all my modules like MMM-Podcast.
                    I played the video and … sound comes from the audio jack again:-(
                    However the usb mic and alexa are still working fine. It is just MMM-Podcast which uses the audio jack.
                    How can that be? I installed the dependecies especially the omxplayer. But that can´t be the reason, or what do you think?
                    lsusb
                    Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
                    Bus 001 Device 005: ID 0d8c:0014 C-Media Electronics, Inc.
                    Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
                    Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                    aplay -l
                      Sub-Geräte: 1/1
                    sudo nano ~/.asoundrc
                    pcm.!default {
                        type asym
                        playback.pcm "plughw:0"
                        capture.pcm  "plughw:1"
                    ctl.!default {
                            type hw
                            card 0
                    Do you have an idea? Seems like I am almost there.
                    Thanks.
