    MMM-MQTT freezes after some time
    2 Posts 2 Posters 2.3k Views 2 Watching
    • K
      Kugelfang
      First of all thanks a lot for this great plugin! I have it running on my RBPi based MM.
      in my scenario it listens to my home assistant which publishes some sensor stats about my home.
      I’m running three instances of this plugin, each listening to a different sensor . If I freshly boot the MM it works until suddenly it freezes and does stop updating the stats. At this point all the other MM plugins continue to work as intended. I checked and the broker actually keeps broadcasting updates values. Hence, I suspect that something with this plugin does not work. In order to get everything working again I need to restart the magic mirror.
      It would be great if someone could help me to fix this.
      • binderthB
        binderth
        @kugelfang said in MMM-MQTT freezes after some time:
        Why don’t you use one instance and configure the subscriptions as shown in the Readme? works for me (presently 5 subscriptions in one instance).
