    MMM-PublicTransportHafas brings up ERRORs `fetchDepartures`
    2 Posts 2 Posters 1.2k Views 2 Watching
      binderth
      Installed and configured MMM-PublicTransportHafas and it shows the same infos I get with the Bahn-App or bahn.de. But on startup I regularly receive those ERRORs - can I avoid those as I don’t know if there’s some side effects attached to them?
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | TypeError: Cannot read property 'fetchDepartures' of undefined
      0|mm       |     at Class.fetchDepartures (/home/pi/MagicMirror/modules/MMM-PublicTransportHafas/node_helper.js:56:12)
      0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-PublicTransportHafas/node_helper.js:21:14)
      0|mm       |     at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
      0|mm       |     at emitTwo (events.js:106:13)
      0|mm       |     at Socket.emit (events.js:194:7)
      0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
      0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:73:7)
      0|mm       |     at process._tickCallback (internal/process/next_tick.js:104:9)
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      sometimes there’s only 3 ERRORs, sometimes there’s more. They don’t show after the appear on (re)start.
      			module: "MMM-PublicTransportHafas",
      			position: "bottom_left",
      				stationID: "xxx",						// Replace with your stationID!
      				stationName: "xxx Bahnhof",				// Replace with your station name!
      				direction: "yyy",						// Show only departures heading to this station. (A station ID.)
      				ignoredLines: [],							// Which lines should be ignored? (comma-separated list of line names)
      				excludedTransportationTypes: ["BuN"],		// Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
      				timeToStation: 10,							// How long do you need to walk to the next Station?
      				timeInFuture: 190,
      				showColoredLineSymbols: true,				// Want colored line symbols?
      				useColorForRealtimeInfo: true,				// Want colored real time information (timeToStation, early)?
      				showTableHeadersAsSymbols: true,			// Table Headers as symbols or text?
      				maxUnreachableDepartures: 2,				// How many unreachable departures should be shown?
      				maxReachableDepartures: 5,					// How many reachable departures should be shown?
      				showOnlyLineNumbers: false					// Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
      PS: stationID is correct, just marked for privacy
        janth
        I got the same issue. But there are other errors as well since I installed PublicTransportHafas.
        Is there any clue why this happens?
        Best,
        Jan
