    MMM-MirrorMirrorOnTheWallSkill not displaying commands/modules on the mirror
    1 Posts 1 Posters 726 Views 1 Watching
    • L Offline
      ladynobeard
      The Mirror Mirror on the wall skill works fine with alexa dot. I get the google images/videos, but none of them, including “turn on/off modules” is displayed on the mirror itself.
      cmd displays:
      magicmirror@2.3.1 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.3.1
      Loading config …
      Loading module helpers …
      Module helper loaded: MMM-MirrorMirrorOnTheWall
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: MMM-MirrorMirrorOnTheWall
      Starting module helper: MMM-MirrorMirrorOnTheWall
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      Whoops! There was an uncaught exception…
      Error: Invalid connect options supplied.
      at new DeviceClient (/home/pi/MagicMirror/modules/node_modules/aws-iot-device-sdk/device/index.js:445:13)
      at Object.DeviceClient [as device] (/home/pi/MagicMirror/modules/node_modules/aws-iot-device-sdk/device/index.js:216:14)
      at Object.app.setup (/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/MirrorMirror.js:12:23)
      at Class.alexa_start (/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/node_helper.js:12:18)
      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-MirrorMirrorOnTheWall/node_helper.js:35:12)
      at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
      at emitTwo (events.js:106:13)
      at Socket.emit (events.js:194:7)
      at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
      at _combinedTickCallback (internal/process/next_tick.js:73:7)
      ^CShutting down server…
      Stopping module helper: updatenotification
      Stopping module helper: calendar
      Stopping module helper: newsfeed
      Stopping module helper: MMM-MirrorMirrorOnTheWall
      Not sure what to do :/
