    Adding a second news feed.
    25 Posts 4 Posters 17.6k Views 4 Watching
      click on the link in the web page to select it (where the page says ‘XML’) , and then copy the URL (address) line
        RIJOSROBERTO
        oooo ok , thank you ,
        so far everything loads up but the live news feed it says loading , so far 5 min have past
        update seems to be stuck at loading , the live video feed
          sdetweil @RIJOSROBERTO
          @rijosroberto might be an error…
          alt-spacebar, n to minimize the mirror screen and see the console log in the terminal window where u did npm start (this will show the debug/errors from the node_helpers)…
          and/or ctrl-shift-i (letter i) to open the debug console, select the console tab
          (this will show the debug from the modules)
            RIJOSROBERTO
            ok ,
            I noticed I had the yellow http:// and the one I copied and pasted so I just erased the blue one and left the yellow one and just rebooted to see
            update ok so far the video feed one just says about the storie and who wrote the storie , it doesn’t show the live feed , trying the regular one now, that one works perfect , still would love the live feed tho any ideas ?
              @rijosroberto i am guessing the RSS module doesn’t know about non-text content…
              from the news items
              media:content url=
                RIJOSROBERTO
                mmmm how can I fix that ? its a fresh install of noobs , and the raspian that the installer recommends , would I need to download a player or some sorts ?
                  the code doesn’t know about anything but the text of the items…
                  you would have to change the code, and use some player, and … I don’t know what else
                    RIJOSROBERTO
                    I suck at coding so that would take me 20 years to at least get a little half way lol is there an alternative
                      @rijosroberto said in Adding a second news feed.:
                      no idea
                      i am a MM newbie
                        RIJOSROBERTO
                        me too , I know they have a module called iframe that can be used to open up smart tiles , but I tried it and it didn’t work for the live feed maybey I did it wrong tho , but it makes me think if mm is able to watch live camara feeds it should be able to watch the news
                        I found this one that iam trying now hopefully it works
                        https://github.com/maxenxe/MMM-RSS-FEED
                          @rijosroberto no… that one doesn’t process the media link either
                            RIJOSROBERTO
                            this one opens it up like a web page
                            https://github.com/alberttwong/MMM-iFrame
                            but no vid I would have to resize it to fit the whole screen , it beats the purpose , of using a pi
                              RIJOSROBERTO
                              do you kno if theres away to go back to the pm2 save ? iam guessing when it saves it backs up?
                                sorry, no… I don’t use PM2
                                  RIJOSROBERTO
                                  I just started doing everything from scratch again I meesed up on the brackets and no matter what I did it wouldn’t work this time ill back it up making an image .
                                      RIJOSROBERTO
                                      ?? what do you mean ??
                                        @rijosroberto i didn’t notice the list had switched to a second page… i had replied, but it didn’t show (on second page), so I accidentally replied again… and then deleted it
