    Change to another SD with bigger size
    9 Posts 3 Posters 2.4k Views 3 Watching
    • H Offline
      Hakupapa
      Hello sean,
      the question is not stupid. I tried but there is no choice in raspi config, because I use noobs. That is also the reason why does fdisk cant write new partitionetable after reboot.
      ? S 2 Replies Last reply Reply Quote 0
        A Former User @Hakupapa
        @hakupapa
        https://dracoy.com/2016/06/26/expanding-partition-on-sd-card-for-raspberry-pi-with-noobs-pre-installed/
        Maybe this could be help, I wish.
          sdetweil @Hakupapa
          @hakupapa do you have another machine in the house where u can put your pictures, and then have the image modules show from there? I do this
          install the samba client, mount the remote volume and then use a symbolic link to it.
          I so liked how this worked out, I built a photo frame with MM, MMM-ImagePhotos (or ImageSlideShow with multiple linked folders), a 32 in tv and a pi…
          added my MMM-SleepWake (to use my webcam as the motion detector)
            sdetweil @Hakupapa
            @hakupapa said in Change to another SD with bigger size:
            I´ve changed to this
            getPhotos: function() {
            var urlApHelper = “/media/pi/B82B-6FB6/fotos”;
            var self = this;
            var retry = true;
            right… the design of both modules depends on the data being IN the modules folder tree
            so, as u have it linked already… just (from the MM folder)
            mkdir modules/MMM-ImagesPhotos/my_fotos
            ln -s modules/MMM-ImagesPhotos/my_fotos  /media/pi/B82B-6FB6/fotos
            then the path modules/MMM-ImagesPhotos/my_fotos can show your photos…
            • H Offline
              Hakupapa
              • H Offline
                Hakupapa @Guest
                @sean
                thx for the link. I tried something like this. But this is much harder and there were a lot of possible mistakes I could make. I think it is easyer to reinstall a new raspian an the magicmirror. I had never thougt, that there is no easy way to move to a bigger sd card, but it seems to be this way.
                • H Offline
                  Hakupapa @Hakupapa
