back screan when start up an errors.....
5 Posts 2 Posters 1.4k Views 2 Watching
    jcklerk
    is have installt it on ubuntu 16.04
    and i have this problem
    it start up whit errors and whit the server Only version i have no errors but still blank screan and th consel on Web Browser is spammed full…
    and when i start it up using npm start it have som errors i cant figger it out what the problem is…
    start up error:
    root@smart-mirror-jcklerk:~/MagicMirror# npm start
    > magicmirror@2.4.1 start /root/MagicMirror
    > sh run-start.sh
    (electron:6583): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
    (electron:6583): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
    Starting MagicMirror: v2.4.1
    Loading config ...
    Loading module helpers ...
    All module helpers loaded.
    Starting server on port 8989 ...
    You're using a full whitelist configuration to allow for all IPs
    Server started ...
    Starting module: newsfeed
    (electron:6583): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
    Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
    Launching application.
    Shutting down server...
    Stopping module helper: updatenotification
    Stopping module helper: calendar
    Stopping module helper: newsfeed
    **test **
    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'test:e2e' ]
    2 info using npm@6.1.0
    3 info using node@v10.7.0
    4 verbose run-script [ 'pretest:e2e', 'test:e2e', 'posttest:e2e' ]
    5 info lifecycle magicmirror@2.4.1~pretest:e2e: magicmirror@2.4.1
    6 info lifecycle magicmirror@2.4.1~test:e2e: magicmirror@2.4.1
    7 verbose lifecycle magicmirror@2.4.1~test:e2e: unsafe-perm in lifecycle true
    8 verbose lifecycle magicmirror@2.4.1~test:e2e: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/root/MagicMirror/node_modules/.bin:/usr/local$
    9 verbose lifecycle magicmirror@2.4.1~test:e2e: CWD: /root/MagicMirror
    10 silly lifecycle magicmirror@2.4.1~test:e2e: Args: [ '-c',
    10 silly lifecycle   'NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive' ]
    11 silly lifecycle magicmirror@2.4.1~test:e2e: Returned: code: 39  signal: null
    12 info lifecycle magicmirror@2.4.1~test:e2e: Failed to exec test:e2e script
    13 verbose stack Error: magicmirror@2.4.1 test:e2e: `NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive`
    13 verbose stack Exit status 39
    13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
    13 verbose stack     at EventEmitter.emit (events.js:182:13)
    13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    13 verbose stack     at ChildProcess.emit (events.js:182:13)
    13 verbose stack     at maybeClose (internal/child_process.js:961:16)
    13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:5)
    14 verbose pkgid magicmirror@2.4.1
    15 verbose cwd /root/MagicMirror
    16 verbose Linux 4.15.0-29-generic
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "test:e2e"
    18 verbose node v10.7.0
    19 verbose npm  v6.1.0
    20 error code ELIFECYCLE
    21 error errno 39
    22 error magicmirror@2.4.1 test:e2e: `NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive`
    22 error Exit status 39
    23 error Failed at the magicmirror@2.4.1 test:e2e script.
    23 error This is probably not a problem with npm. There is likely additional logging output above.
    24 verbose exit [ 39, true ]
    i hope sam one can help me
    ? 1 Reply Last reply Jul 25, 2018, 3:18 PM Reply Quote 0
      jcklerk
      chek:
      npm install errors magicmirror@2.4.1 &
      dbus-deamon is running under the user jcklerk and i start up magicmirror whif root user
      but still black screen
        A Former User @jcklerk
        @jcklerk
        Try this.
        npm start -- --disable-gpu
        In my case, it worked.
        J 1 Reply Last reply Jul 25, 2018, 4:10 PM Reply Quote 0
          jcklerk @Guest
          @sean Nope doesn’t work for me…
          root@smart-mirror-jcklerk:~/MagicMirror# npm start -- --disable-gpu
          > sh run-start.sh "--disable-gpu"
          (electron:7962): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
          (electron:7962): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
          Loading config ...
          Server started ...
          (electron:7962): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
            jcklerk
            I’m are going to re install ubuntu and chek if i have the same error bicase i have som oudio problems whit google assistant after i install magicmirror…
              jcklerk
              chek:
