    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
    • T
      Tabbe @Guest
      @sean said in MMM-CalendarExt:
      @tabbe
      https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#defaultview
      Use dateFormat
      I did try with that but still it remains unchanged.
              current: {
                              title: "Test",
                              dateFormat: "dddd",
                              titleFormat: "dddd",
                              overTitleFormat : "dddd",
                              position: 'top_left',
                              useRelative: 0,
                              limit:2
      I also tried without other formating and with basic M.D format.
      alt text
        A Former User @Tabbe
        @tabbe ‘dddd’ means the weekday name of target date/time. What exactly do you want to display as?
        • T
          Tabbe @Guest
          @sean
          I want to display weekday name, like saturday.
            @tabbe
            I think you’ve missed useRelative field in your config. the default value of useRelative of current & upcoming is 1 or true.
            Set it as 0.
            upcoming: {
                        dateFormat: "dddd",
                        timeFormat: "HH:mm",
                        limit: 5,
                        useRelative: 0
            If you want to display only “Saturday” without time, unfortunately it is not supported. (Do you need? e.g. only starting time?)
              @tabbe
              Now, I’ve updated module to display only starting time.
              You can set like this;
              upcoming: {
                          dateFormat: "dddd",
                          timeFormat: " ", // don't use `""` instead `" "`
                          limit: 5,
                          useRelative: 0,
                          onlyStartingTime: 1,
              And you can see like this.
              • T
                Tabbe @Guest
                @sean
                This is weird. I did update module and still not getting like that.
                :~/MagicMirror/modules/MMM-CalendarExt$ git pull
                Already up-to-date.
                Also, I would like it to be on current since it shows current date event. What I am trying to show is birthdays and suchs.
                  @tabbe
                  Hmmm. weird,
                  As you can see on github page, 40mins ago I updated the module.
                  And you can use that config in current view also.(above is just sample)
                  • T
                    Tabbe @Guest
                    @sean
                    Ah, somehow it is now working. Thanks!
                      SK4018
                      Hi all,
                      I love the ‘daily’ view (as seen in the post just above), as it presents both events for 7 days and times. However, I want them it to stay at a “Monday to Sunday” order. Is this possible with the daily view? Thanks
                        A Former User @SK4018
                        @sk4018
                        I think you can use weeks view instead daily view. But starting weekday depends on which locale are you using.
                        • V
                          Vauxdvihl @Guest
                          @sean
                          Thx a lot
                          It works
                          Greetz
                            redink
                            I just updated this module, and it stopped working. I even tried resting to the simple config from the readme, and nothing is coming up. Where can I see the logs for it to try and fix this?
                              A Former User @redink
                              @redink
                              stop pm2 mm then npm start dev in your MM directory root.
                              • V
                                Vauxdvihl
                                @Sean
                                Sorry to ask again
                                Is there any possibility to increase a little bit the size of the letters?
                                I mean the ones showing in the calendar as a “task”?
                                thanks
                                  A Former User @Vauxdvihl
                                  @vauxdvihl
                                  You can adjust anything in CSS. (It could not be so easy but really funny)
                                  Or tell me which letters to be increased.
                                  • V
                                    Vauxdvihl
                                    @Sean
                                    I want to play around with the following values
                                    Increase / Decrease “FINAL: SEA7 - OAK 6”
                                    Increase / Decrease “Time (04:05-07:05)”
                                    I am not a programmer :-)
                                    Thanks a lot
                                      @vauxdvihl
                                      Add this into your MagicMirror/css/custom.css file.
                                      .CALEXT .eventTime {
                                        font-size: 120%;
                                        line-height:110%;
                                      .CALEXT .eventContent {
                                        font-size: 140%;
                                        line-height:110%;
                                      You can adjust these values with relative % or absolute px (Or many other various things)
                                      https://www.w3schools.com/cssref/pr_font_font-size.asp
                                      • V
                                        Vauxdvihl
                                        @Sean
                                        Thanks a lot
                                        In custom css file a have the following:
                                        div.CALEXT  .event .symbol {
                                            order:1;
                                            display:block;
                                            flex-basis: 30px; // Modify this
                                            text-align:center;
                                            min-width: 50px; // Modify this
                                            font-size: 150%; // Add this
                                        div.CALEXT .events .symbol.emoji {
                                            font-size: 150%; //Adjust this as your wish. you can use px or %
                                        div.CALEXT .events .symbol.font-awesome {
                                            font-size: 250%; //Adjust this as your wish. you can use px or %
                                        div.CALEXT .tableStyle .eventTime {
                                            display:block;
                                          font-size: 80%;
                                          line-height:110%;
                                          font-size: 250%;
                                          line-height:110%;
                                        The adjustment of time works fine.
                                        But not of the initial content.
                                        Sorry
                                        But can you please help again
                                        Thanks a lot
                                          @vauxdvihl
                                          Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
                                          Anyway, you can use like this;
                                           div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
                                             font-size: 250%;
                                             line-height:110%;
                                          (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
                                          • Y
                                            yoey2112
                                            Hello @Sean ,
                                            Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
                                            -Yoey
                                            • 10
                                            • 5 / 10
