    MMM-Timetable
    43 Posts 12 Posters 26.4k Views 13 Watching
      [[global:former-user]] @electros
      @electros I’ll consider.
        @electros
        I’ve added function of reading schedule from comma(,) separated text file(or csv).
        E 1 Reply Last reply Reply Quote 1
          maxbachmann
          awesome :)
          • E Offline
            electros Project Sponsor @Guest
            @sean Wow, so fast thank you very much. I tested and everything is fine, thank you again for a great work.
            • zdenekZ Offline
              zdenek @Guest
              @sean amazing, thanks. Just a question - my kids have different Timetable for odd and for even week. Is there way how to show them the correct one? Now Iˇve visible in Cal module the number of week and in TimeTable they have 2 rows (odd/even). Or can be still on 2 rows, but use different colors for odd and even?
              Thanks, Zdeněk
                [[global:former-user]] @zdenek
                @zdenek
                Wow, It’s a very odd timetable which has never been imagined. :)
                Do you need the 2 timetables are displayed at the same time always? or Just 1 timetable for the right week at that time?
                  @zdenek
                  0) display 2 timetables together;
                  Hmmm… I think it’s hard. I had considered that case at the development, but gave up. because I thought the screen was too small to display complex timetables.
                  1. display 2 timetables by rotation
                  refreshInterval: 1000*60,
                  schedules: [
                      title: "Even Weeks",
                      schedule: [ ... ]
                      title: "Odd Weeks",
                      schedule: [ ... ]
                  This would make a rotation of timetables per every 1 minutes.
                  1. Display right timetable of that week.
                    I think it could be done by new feature - reading schedule from file.
                    Prepare 2 csv files, - even.csv, odd.csv
                    And you can add below code into your crontab to change from each .csv to thisweek.csv
                  0 8 * * 6 test $((10#$(date +\%W)\%2)) -eq 1 && cp /your/path/odd.csv /your/paht/thisweek.csv || cp /your/path/even.csv /your/path/thisweek.csv
                  This will copy odd.csv or even.csv to thisweek.csv on each Saturday.
                  The configuration could be like this;
                  schedules: [
                      title: "My Kids Timetable",
                      file: "thisweek.csv",
                  I didn’t test but you can catch the idea.
                  • V Offline
                    Vauxdvihl
                    @Sean
                    Thanks a lot for this module
                    For testing i have simply copied your example to my config.
                    But i am not able to get it running
                    The screen stays black
                    Any idea
                    Do i have to use the lastest version of the magic mirror sw?
                    Thanks a lot
                    Greetz
                    0|mm       | Shutting down server...
                    0|mm       | > magicmirror@2.4.1 start /home/pi/MagicMirror
                    0|mm       | > sh run-start.sh
                    0|mm       | Starting MagicMirror: v2.4.1
                    0|mm       | Loading config ...
                    0|mm       | Loading module helpers ...
                    0|mm       | No helper found for module: clock.
                    0|mm       | No helper found for module: alert.
                    0|mm       | No helper found for module: MMM-Timetable.
                    0|mm       | All module helpers loaded.
                    0|mm       | Starting server on port 8080 ...
                    0|mm       | Server started ...
                    0|mm       | Sockets connected & modules started ...
                    0|mm       | Launching application.
                      //disabled:true,
                      module: "MMM-Timetable",
                        timeFormat: "hh:mm A",
                        height: "800px",
                        width: "150px",
                        mode: "5days", // "today", "5days", "7days"
                        displayEndTime:true, //whether display endTime on timeline or not.
                        schedules: [ //array of schedules
                            title: "Slytherin 2nd Year",
                            file: null, // or "test.csv" - comma separated text file. (see `test.csv`)
                            schedule: [
                              // [weekday, starttime(24h), endtime(24h), title, subtitle, backgroundColor(optional)]
                              // weekday : 1 for Monday, 2 for Tuesday, ... 7 for Sunday
                              [1, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                              [2, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                              [3, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                              [4, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                              [5, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                              [1, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                              [2, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                              [3, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                              [4, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                              [5, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                              [1, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                              [2, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                              [3, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                              [4, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                              [5, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                              [1, "1100", "1145", "Transfiguration", "w/Ravenclaw"],
                              [1, "1315", "1400", "Charms", "w/Hufflepuff"],
                              [2, "0915", "1045", "Transfiguration", "w/Ravenclaw"],
                              [2, "1500", "1630", "Herbology", "w/Ravenclaw"],
                              [3, "0915", "1045", "Defense Against The Dark Art", "w/Gryffindor", "rgba(255,0,0,0.5)"],
                              [3, "1100", "1145", "Charms", "w/Hufflepuff"],
                              [3, "1315", "1445", "History of Magic", "w/Hufflepuff"],
                              [3, "1500", "1630", "Potions", "w/Gryffindor"],
                              [4, "1100", "1145", "Defense Against The Dark Art", "w/Gryffindor"],
                              [5, "1315", "1400", "Potions", "w/Gryffindor"],
                            title: "Slytherin 2nd Year (only classes)",
                            schedule: [
                      [[global:former-user]] @Vauxdvihl
                      @vauxdvihl
                      I have no problem…
                      Try this;
                            //disabled:true,
                              file:"test.csv"
                      Or just
                      • V Offline
                        Vauxdvihl
                        @sean said in MMM-Timetable:
                        module: “MMM-Timetable”,
                        position: “top_right”,
                        This is strange
                        No error message and nothing shown on the screen
                        I have generated a test config file (contains only the timeline)
                        Hmm i need to check it
                        • V Offline
                          Vauxdvihl
                          • V Offline
                            Vauxdvihl @Guest
                            @sean
                            I have done it
                            • V Offline
                              Vauxdvihl @Vauxdvihl
                              @Sean
                              Can i change the timeformat to European one?
                              like 22:30?
                                @vauxdvihl
                                Set timeFormat as “HH:mm”
                                • V Offline
                                  Vauxdvihl
                                  @Sean
                                  Thanks it works
                                  But i see there comes something strange
                                  Setting these value to “HH:MM” the time datas from my conifg are not matching with the displayed datas.
                                  Can you reproduce this?
                                  Regards
                                    @vauxdvihl
                                    Not ‘HH:MM’, it’s ‘HH:mm’
                                    • V Offline
                                      Vauxdvihl @Guest
                                      @sean
                                      Thanks a lot
                                      • L Offline
                                        lovesicker
                                        @Sean
                                        How can I redefine the rows to equal altitude, regardless of time interval? I’d like to define equal altitude for each rows.
                                        Could you or anyone give me some suggestions? Thanks in advance.
                                          [[global:former-user]] @lovesicker
                                          @lovesicker
                                          Not possible currently. Heights are dependent on duration.
                                          I’ll consider it on next update but You’d better to display static table your own with some iframe or html module.(My MMM-HTMLBox can show static html on MM)
                                          • L Offline
                                            lovesicker @Guest
                                            @Sean
                                            OK, I got it. Thanks for your reply.Let me try your MMM-HTMLBox.
                                            Hahahah, I found I already become one of your fans. After trying out a module several days,I found it is coded by you,ig.,MMM-GroveGesture,MMM-CalendarExt.
                                            I’m looking forward to next version about MMM-Timetable.
                                            Have a good day!
                                            • 2 / 3
