    Needing help - MagicMirror sometimes working
    2 Posts 1 Posters 922 Views 1 Watching
      blebbens
      Hi there,
      i took my 1-year-old MagicMirror and switched from a Raspberry Pi 3B to a 3B+. I flashed the newest Raspbian Stretch to my SD card and installed MagicMirror 2.41 without any problems.
      After installing a couple of modules, I added a python script to crontab for fan controlling in cases of a system temperature over 58 degrees.
      I set up the PIR-sensor for switching on/off the monitor behind the mirror using MMM-Display-Controller - it is not a module.
      All this hardware and software was working in my old MagicMirror-Setup. The difference from the old to the new MagicMirror is the MagicMirror Version 2.41, Raspberry 3B+ and the fan python script.
      The new setup was working fine, too, including the PIR-sensor. But, after running fine for 1-2 boot sequences, it all comes to the same:
      • the system boots up into MagicMirror and shows all the working modules. If no one is in front of the mirror, the monitor switches off. If the motion sensor detects a person, a blank screen is coming up, without any modules
      • or, the monitor shows half of the modules at various places
      • or, the monitor shows all the working modules, but the screen freezes (clock is not counting time etc)
      Sometimes, the system is answering via SSH - sometimes, it answers after a couple of minutes.
      I am very dissapointed - put a lot of work into this mirror…
      Could someone help ?
      Why is the new installed system freezing or showing a blank screen after all was working fine ? Are there any known problems with the Raspberry Pi 3B+ ? Is there a log I can post ?
      Thanks in advance…
        blebbens
        Anyone?
        Monitor is freezing or switching on/off all the time…
