    Calendar entries showing end time.
    7 Posts 2 Posters 2.7k Views 2 Watching
      Richard238
      Since installing the last 8 commits, calendar is now showing the end time of events.
      All-day events, e.g. birthdays, span two days.
      What’s changed, how do I get it back to normal?
      Thanks.
        Richard238
        Strange, does no-one else have the same issue?
          Alvinger
          It is one of the new features in the latest beta. You can turn it off in config.js.
            Richard238 @Alvinger
            @alvinger said in Calendar entries showing end time.:
            Excellent!. How, what needs to be changed?
              Alvinger @Richard238
              @richard238 just set showEnd to false.
              showEnd: false,
                Richard238
                That’s fixed it, thank you.
                The “showEnd:” parameter wasn’t listed in my config.js. When was that changed, where’s the documentation?
                  Alvinger
                  I don’t really know. I just stumbled upon it browsing through the code in the development branch as I was thinking about implementing end times in my mirror. :slightly_smiling_face:
                  It is not even documented in the README, you have to look in calendar.js to find out about the new options.
                  When the code is moved to the master branch I am sure they will update the documentation (and also change some defaults to be non-reaking such as showEnd which should be false by default)
