    MMM-MirrorMirrorOnTheWall error while configuring Alexa skill
    14 Posts 6 Posters 6.1k Views 6 Watching
      Monilshah @richland007
      @richland007 Thanks for replying.
      I drag and drop the contents of speechAssets to it and it still gives same error when i click on Build Model.
      richland007R 1 Reply Last reply Reply Quote 0
      • richland007R Offline
        richland007 @Monilshah
        @monilshah Are you sure you have done the other steps correctly before the speechAssets part?
          Monilshah
          @richland007 Yes i a am sure.
          Here’s the steps i did
          Step 1 : On Alexa Developer i clicked on create skill
          Step 2 : Named the skilled, selected a Custom model and clicked on Create Skill
          Step 3 : Choose Start from scratch template
          Step 4 : Click on Invocation on the left menu bar. Set “magic mirror” as the invocation name (Save Model)
          Step 5 : Clicked on JSON editor, I drag and drop the contents of speechAssets to it.
          Lemme know if i had skipped any steps.
          I even tried to create a new skill following same steps but got the error at the same part…
            Robalot @Monilshah
            @monilshah I just read this.
            " Important: AMAZON.LITERAL is deprecated as of October 22, 2018. Older skills built with AMAZON.LITERAL do continue to work, but you must migrate away from AMAZON.LITERAL when you update those older skills, and for all new skills."
              Monilshah
              @Robalot Hey thanks for the info.
              So that’s the reason i was getting all those errors.
              Someone will have to change InteractionModel.json file or else it wont work…
              now the biggest problem is I don’t know what to do next because i dont know how to code… :(
                @monilshah You are far away from having it work my friend even if you could tackle this new issue you ran across. We had not even heard about this before now but been working at it long before October 22.
                Check this two threads out and read them thoroughly from the beginning and maybe with some luck who knows what may happen…it didn’t happen for me… still going at it though :)
                https://forum.magicmirror.builders/topic/8569/mmm-mirrormirroronthewall-installation-issue/59
                and
                https://forum.magicmirror.builders/topic/1532/mmm-mirrormirroronthewall-alexa-voice-control-to-hide-show-modules-and-display-text-images/182?page=19
                Denis
                  Monilshah
                  @richland007 Will try to figure out a way to fix this new issue & will go through those threads. Thanks :)
                  If anyone has already fixed then please share…
                    mozarsi
                    @Monilshah I am getting the same error while building the interaction model. If you figure out a way to create appropriate custom slots and succeed in building the model, please update !
                    • G Offline
                      gkim36
                      I solved this issue by editing the .json file without using AMAZON.LITERAL here is the guide to do it: https://developer.amazon.com/docs/custom-skills/literal-slot-type-reference.html
                      I believe there is also a pull request made by someone else in MMM-MirrorMirroOnTheWallSkill git page. He includes his new json file for interaction model.
                      I also have the correct json file if you need it.
                      Good luck!
                      richland007R F 2 Replies Last reply Reply Quote 0
                        richland007 @gkim36
                        @gkim36 can you please share the interaction model model somehow i think my skill is not working right just because of it.
                        I have also found out that there is regional keyboard differences with with the consistency of ( ', " and other syntax symbols) when copy-pasting text so i have a drop box folder i can share with you to put the interaction model file if that is the case rather than copy pasting it here.
                        thank you
                        Denis
