    TV Tuner
    20 Posts 6 Posters 10.4k Views 6 Watching
    • Cr4z33C Offline
      Cr4z33 @evroom
      @evroom said in TV Tuner:
      I got streaming from a Linux SAT receiver with enigma2 working, using the module MMM-RTSPStream-
      But you will need to supply a bit more information than rather ‘a TV tuner’.
      I am upping this because this is EXACTLY what I was looking for.
      I’ve got a Vu+ Duo² and I want to include a streaming frame into my next coming MagicMirror project.
      Can you tell me if I have to setup the wanted channels into the config script or if I can switch them live by i.e using Google Assistant?
      At the end of the day I just want to choose between 2-3 news TV channels and 3 radio channels. :)
      • evroomE Online
        evroom
        @Cr4z33
        Please find below an example for streaming from an Enigma2 box.
        The most important line is the url.
        The other lines are custom-made for my 2 camera streams.
        The url is taken from VLC, which I use to stream SAT TV to my PC.
        A few remarks on what I experienced:
        For Raspberry Pi, you may need the MPG2 license in order to be able to stream the satellite TS stream.
        The Raspberry Pi 3 Model 3 and omxplayer can only handle 1 TS stream, as it appears to be the case.
        And a maximum 3 RTSP camera streams.
        Perhaps more powerful HW can handle more.
        I did not look into the possibility of choosing between streams / channels.
        This needs some additional programming or even forking the code to make it specific for TS streams.
        Hope it helps.
        config.js :
          module: "MMM-RTSPStream",
          disabled: false,
          position: "middle_center",
          header: "Axis Security Monitor",
            autoStart: true,
            rotateStreams: false,
            moduleWidth: 900,
            moduleHeight: 364,
            localPlayer: 'omxplayer',
            remotePlayer: 'none',
            showSnapWhenPaused: false,
            remoteSnaps: false,
            stream1: {
            url: 'http://192.168.178.28:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:', // ZDF HD
              protocol: "tcp",
              width: 590,
              height: 332
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
        • Cr4z33C Offline
          Cr4z33 @evroom
          @Cr4z33
          Hope it helps.
          config.js :
            disabled: false,
              autoStart: true,
              moduleWidth: 900,
              moduleHeight: 364,
              remoteSnaps: false,
              stream1: {
                protocol: "tcp",
                width: 590,
                height: 332
          Thank you for your precious reply as I was just going to PM you asking exactly for that information!
          I still have to see what the Google Assistant integration can do with channels switching, but it wouldn’t be so bad at the end if I will be able to see only one channel. :)
          Going to try it in the next few hours when I finally get all the stuff needed for the smart mirror.
          • Cr4z33C Offline
            Cr4z33
            So I got everything running (but HD channels).
            Now @evroom (or @shbatm ) do you know if there is a way to get rid of the white frame under the video streaming? :grimacing_face:
            alt text
            • evroomE Online
              evroom
              I remember it took me quite a while to have it to my likings (size and position of the window(s)).
              The width and height of the stream defines the size of your video.
              The width and height in the config defines the place of the stream and what you actually see.
              A bit difficult to explain.
              Works like a “sjabloon”, template.
              Could you show your MMM-RTSPStream config settings and also a part of the ‘pm2 logs MagicMirror’ output ?
              Where it says: “Starting stream stream1 with args: [”.
              Test environment:
              • evroomE Online
                evroom
                Try this:
                # vi /home/pi/MagicMirror/css/custom.css
                .MMM-RTSPStream .innerWrapper {
                  border-style: none;
                # pm2 restart MagicMirror
                I would still try to have the video window and the module window overlap each other, as it perhaps may influence the position and aligning of other modules.
                Test environment:
                • Cr4z33C Offline
                  Cr4z33 @evroom
                  		    position: "bottom_right",
                  		    // header: "Sky TG24",
                  		        autoStart: true,
                  		        rotateStreamTimeout: 10,
                  		        moduleWidth: 390,
                  		        moduleHeight: 219,
                  		        remoteSnaps: false,
                  		        stream1: {
                  		            // name: 'Sky TG24',
                  		            // url: 'http://192.168.1.6:8001/1:0:1:5:7918:217C:EEEE0000:0:0:0:',
                  		            name: 'RAI 3 TGR Puglia',
                  		            url: 'http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:',
                  		            // name: 'RAI 3 HD',
                  		            // hdUrl: 'http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:',
                  		            protocol: "tcp",
                  		            frameRate: 'undefined',
                  		            width: 390,
                  		            height: 219,
                  Hmm for some reason the log looks empty. :thinking_face:
                  pi@raspberrypi:~ $ pm2 logs MagicMirror --lines 100
                  [TAILING] Tailing last 100 lines for [MagicMirror] process (change the value with --lines option)
                  • Cr4z33C Offline
                    Cr4z33 @evroom
                    Try this:
                      border-style: none;
                    Sorry I am still a Linux/Raspberry noob so I couldn’t figure out how to edit custom.css with that script.
                    However this is how it looks right now:
                     * Magic Mirror                                      *
                     * Custom CSS                                        *
                     * By Michael Teeuw http://michaelteeuw.nl           *
                     * MIT Licensed.                                     *
                     * Add any custom CSS below.                         *
                     * Changes to this files will be ignored by GIT. *
                     body {
                    Last but not least thank you very much for your support! :flexed_biceps_medium-light_skin_tone:
                    PS for the forum admins: for some reason I am not getting emails for new replies although I am subscribed and the spam folder is empty!
                    • evroomE Online
                      evroom
                      @Cr4z33,
                      You can put the code end the end of the file, so after the body stuff.
                      If you are not familiar with vi, you can use nano:
                      $ nano /home/pi/MagicMirror/css/custom.css
                      I have made some changes in the body part, to change the screen margins, etc.
                      body {
                             margin: 10px;
                             height: calc(100% - 10px);
                             width: calc(100% - 10px);
                      Test environment:
                      Cr4z33C 2 Replies Last reply Reply Quote 0
                      • Cr4z33C Offline
                        Cr4z33 @evroom
                        @evroom a-ha alright thanks!
