    Anyone else experiencing issues after updating Raspbian (black screen and wifi dropping)
    9 Posts 3 Posters 3.2k Views 3 Watching
    • Y Offline
      yep_DD
      Hi guys,
      I have updated Raspbian yesterday and ever since my mirror runs for a few minutes and then the screen goes blank. Nothing is in the logs and electron is still running. When I restart it -occassionally- I get resolve errors for github and stuff like that. But pin g / curl and everything works fine via shell.
      edit: Webinterface is running. Could it be that the screensaver is active? I have always had it disabled in the LXDE and LXDE-pi config.
      Any ideas?
      KR,
      Stephan
      • Y Offline
        yep_DD
        Solution for screensaver blanking:
        add:
        @xset s noblank
        @xset s off
        @xset -dpms
        to:
        /home/pi/.config/lxsession/LXDE-pi/autostart
        Note: setting it in
         /etc/xdg/lxsession/LXDE-pi/autostart or /etc/xdg/lxsession/LXDE/autostart
        did not work anymore, the user files take precedence.
        I don’t know why it changed with the latest Raspbian Update or what I did wrong, but if I don’t add the xset commands as above and check with
        DISPLAY=:0 xset -q
        the screensaver stays enabled. If you guys need to verify it is disabled, just run the above command and check if the following lines appear like that:
        Screen Saver:
          prefer blanking:  no    allow exposures:  yes
          timeout:  0    cycle:  600
        DPMS (Energy Star):
          Standby: 600    Suspend: 600    Off: 600
          DPMS is Disabled
        If blanking and timeout are yes and not 0 the screensaver is active (DPMS should also show disabled)
        • Y Offline
          yep_DD
          Update: it seems all the xset options I set are now being ignored, manually disabling the screensaver brings the mirror back.
          Update2: It seems also the wifi connections now gets reset every couple of minutes which may cause the resolve error I saw earlier in the logs
          • Y Offline
            yep_DD
            add:
            @xset s noblank
            @xset s off
            @xset -dpms
            to:
            Note: setting it in
            DISPLAY=:0 xset -q
            Screen Saver:
            DPMS (Energy Star):
              DPMS is Disabled
            • Y Offline
              yep_DD
              For Wifi Problems I added:
              iwconfig wlan0 power off
              to
              sudo nano /etc/rc.local
              now checking the output with
              iwconfig wlan0
              gives me:
              Power Management:off
              let’s see if it is solved.
                MWel1977
                @yep_DD
                Hi There Stephan, I have the same problem with the black screen.
                After start the MM runs for some time and then it just goes to a black screen.
                I added the 3 lines to the autostart file and checked if the timeout and prefer blanking are set to 0 and no… and they are!
                I’m running MM2 this moment on a 24" screen to see if it stays on.
                I’ll let it run for some time. Hope it stays on!
                THANKS for the tutorial.
                Kind regards Mike
                • Y Offline
                  yep_DD @MWel1977
                  @mwel1977 let me know if it worked :). Was it “600 and yes” before the change?
                    MWel1977
                    @yep_DD I don’t know what the values were before I changed it but the values are currently NOT “yes” but “0” and “no”. And I didn’t let the MagicMirror just sit there doing nothing yesterday…
                    I was installing modules and testing them. :smiling_face_with_halo: :smiling_face_with_halo:
                    But I need to solve a module error tonight so I’ll start the MagicMirror as soon as I get home so it can stay like that for about an hour. If it’s still on then it’s okay! :thumbs_up:
                    I’ll let you know!
                      MWel1977
                      @yep_DD the MagicMirror is running almost 4 hours strait on end now.
                      I would call that: screensaver disabled!:winking_face:
                        robiv8
                        i have the latest Stretch and no folder lxsession in /.config
                        what now?
                        Sorry, I found it
                        Note: setting it in
