    Struggling with Pi0
    8 Posts 2 Posters 2.4k Views 2 Watching
      rgatlin
      I am determined to get MM running on this Pi0, but I have gotten stuck. I have everything installed and when I run ‘npm start’, it looks to me like the server is starting correctly. I go to the Chromium browser and try ‘localhost:8080’, but it doesn’t connect. I also tried 0.0.0.0:8080, but it performs a websearch.
      I go into the GUI, then MM file and click index.html and I get a black screen.
      I can post code output if necessary, but I am hoping I am just doing something wrong and stupid.
      Thanks in advance and Happy New Year!
        andyc7687
          rgatlin
          That would be great. Thanks!
          What is the correct way see the display? Is it the browser with the localhost:8080 address?
          Thanks again for the help.
            andyc7687
            I believe the issue is that there are elements of nodejs that don’t get installed correctly using npm on the pi zero. Attached is a shell script that should do it from a fresh Raspbian Stretch Install. I put all the files in the home directory (~) and it all distributes itself from there by running RaspberryPi0.sh
            Let me know if that helps!
            [3_1546385331101_startMagicMirror.sh](Uploading 100%) [2_1546385331101_RaspberryPi0.sh](Uploading 100%) [1_1546385331100_pm2_MagicMirror.json](Uploading 100%) [0_1546385331099_chromium_start.sh](Uploading 100%)
              andyc7687
              I don’t know if those files uploaded…
              startMagicMirror.sh: EDIT: I uploaded the wrong code just for this file; changes are a semi colon after line 2 and at the end of line 4; plus the directory has changed from
              /home/pi/chromium_start.sh to /home/pi/MagicMirror/PiZero/chromium_start.sh in line 5
              #!/bin/bash
              cd ~/MagicMirror;
              node serveronly &
              sleep 30;
              sh /home/pi/MagicMirror/PiZero/chromium_start.sh
              chromium_start.sh
              #!/bin/sh
              unclutter &
              chromium-browser --start-fullscreen --app http://localhost:8080
                "apps" : [{
                  "name"        : "MagicMirror",
                  "script"      : "~/MagicMirror/PiZero/startMagicMirror.sh",
                  "watch"       : ["/home/pi/MagicMirror/config/config.js"]
              RaspberryPi0.sh
              #!/bin/bash
              #Pi Zero Install, largely plagiarised from MagicMirror2's raspberry.sh shell script for Pi2 and Pi3
              echo 'Updating Pi'
              sudo apt-get update;
              echo 'Upgrading Pi'
              sudo apt-get upgrade;
              sudo apt-get upgrade --fix-missing;
              echo 'Downloading node v11.6.0'
              curl -o node-v11.6.0-linux-armv6l.tar.gz  https://nodejs.org/dist/v11.6.0/node-v11.6.0-linux-armv6l.tar.gz; #Most up to date recent version
              echo 'Extracting node v11.6.0'
              tar -xzf node-v11.6.0-linux-armv6l.tar.gz; # extract files
              echo 'Extracting node and npm'
              cd node-v11.6.0-linux-armv6l/;
              sudo cp -R * /usr/local/;
              cd ~;
              sudo apt install git; sudo apt install unclutter;
              echo 'Cloning Magic Mirror'
              git clone https://github.com/MichMich/MagicMirror;
              cd MagicMirror;
              echo 'Installing Magic Mirror Dependencies'
              npx npmc@latest install; npm install acorn@latest; npm install stylelint@latest; npm audit fix;
              echo 'Loading default config'
              # Use sample config for start MagicMirror
              cp config/config.js.sample config/config.js;
              #Set the splash screen to be magic mirror
              THEME_DIR="/usr/share/plymouth/themes"
              sudo mkdir $THEME_DIR/MagicMirror
              sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script;
              sudo plymouth-set-default-theme -R MagicMirror;
              mkdir ~/MagicMirror/PiZero;
              sudo mv ~/startMagicMirror.sh ~/MagicMirror/PiZero/startMagicMirror.sh;
              sudo mv ~/pm2_MagicMirror.json ~/MagicMirror/PiZero/pm2_MagicMirror.json;
              sudo mv ~/chromium_start.sh ~/MagicMirror/PiZero/chromium_start.sh;
              sudo chmod a+x ~/MagicMirror/PiZero/startMagicMirror.sh;
              sudo chmod a+x ~/MagicMirror/PiZero/pm2_MagicMirror.json;
              sudo chmod a+x ~/MagicMirror/PiZero/chromium_start.sh;
              # Use pm2 control like a service MagicMirror
              sudo npm install -g pm2;
              sudo su -c "env PATH=$PATH:/usr/bin pm2 startup systemd -u pi --hp /home/pi";
              pm2 start /MagicMirror/PiZero/pm2_MagicMirror.json;
              pm2 save;
              echo 'Magic Mirror should begin shortly'
              Takes about an hour depending on how up to date your Raspbian image is… I haven’t silenced/run any of the things in the background so you might get a couple of prompts where you just have to press enter (normally during the apt-get upgrade phase)
                rgatlin
                I will give this a try. Thanks for your help!
                  andyc7687
                  no worries. if you want to have a bit more control over it, you can execute each line of RaspberryPi0.sh (minus the echo requests) directly in the terminal.
                    andyc7687 @rgatlin
                    @rgatlin Did that work for you?
                    if now working, can you mark the post as solved please :)
