    Struggling with Pi0
    8 Posts 2 Posters 2.3k Views 2 Watching
      andyc7687
      I believe the issue is that there are elements of nodejs that don’t get installed correctly using npm on the pi zero. Attached is a shell script that should do it from a fresh Raspbian Stretch Install. I put all the files in the home directory (~) and it all distributes itself from there by running RaspberryPi0.sh
      Let me know if that helps!
      [3_1546385331101_startMagicMirror.sh](Uploading 100%) [2_1546385331101_RaspberryPi0.sh](Uploading 100%) [1_1546385331100_pm2_MagicMirror.json](Uploading 100%) [0_1546385331099_chromium_start.sh](Uploading 100%)
        andyc7687
        I don’t know if those files uploaded…
        startMagicMirror.sh: EDIT: I uploaded the wrong code just for this file; changes are a semi colon after line 2 and at the end of line 4; plus the directory has changed from
        /home/pi/chromium_start.sh to /home/pi/MagicMirror/PiZero/chromium_start.sh in line 5
        #!/bin/bash
        cd ~/MagicMirror;
        node serveronly &
        sleep 30;
        sh /home/pi/MagicMirror/PiZero/chromium_start.sh
        chromium_start.sh
        #!/bin/sh
        unclutter &
        chromium-browser --start-fullscreen --app http://localhost:8080
          "apps" : [{
            "name"        : "MagicMirror",
            "script"      : "~/MagicMirror/PiZero/startMagicMirror.sh",
            "watch"       : ["/home/pi/MagicMirror/config/config.js"]
        RaspberryPi0.sh
        #!/bin/bash
        #Pi Zero Install, largely plagiarised from MagicMirror2's raspberry.sh shell script for Pi2 and Pi3
        echo 'Updating Pi'
        sudo apt-get update;
        echo 'Upgrading Pi'
        sudo apt-get upgrade;
        sudo apt-get upgrade --fix-missing;
        echo 'Downloading node v11.6.0'
        curl -o node-v11.6.0-linux-armv6l.tar.gz  https://nodejs.org/dist/v11.6.0/node-v11.6.0-linux-armv6l.tar.gz; #Most up to date recent version
        echo 'Extracting node v11.6.0'
        tar -xzf node-v11.6.0-linux-armv6l.tar.gz; # extract files
        echo 'Extracting node and npm'
        cd node-v11.6.0-linux-armv6l/;
        sudo cp -R * /usr/local/;
        cd ~;
        sudo apt install git; sudo apt install unclutter;
        echo 'Cloning Magic Mirror'
        git clone https://github.com/MichMich/MagicMirror;
        cd MagicMirror;
        echo 'Installing Magic Mirror Dependencies'
        npx npmc@latest install; npm install acorn@latest; npm install stylelint@latest; npm audit fix;
        echo 'Loading default config'
        # Use sample config for start MagicMirror
        cp config/config.js.sample config/config.js;
        #Set the splash screen to be magic mirror
        THEME_DIR="/usr/share/plymouth/themes"
        sudo mkdir $THEME_DIR/MagicMirror
        sudo cp ~/MagicMirror/splashscreen/splash.png $THEME_DIR/MagicMirror/splash.png && sudo cp ~/MagicMirror/splashscreen/MagicMirror.plymouth $THEME_DIR/MagicMirror/MagicMirror.plymouth && sudo cp ~/MagicMirror/splashscreen/MagicMirror.script $THEME_DIR/MagicMirror/MagicMirror.script;
        sudo plymouth-set-default-theme -R MagicMirror;
        mkdir ~/MagicMirror/PiZero;
        sudo mv ~/startMagicMirror.sh ~/MagicMirror/PiZero/startMagicMirror.sh;
        sudo mv ~/pm2_MagicMirror.json ~/MagicMirror/PiZero/pm2_MagicMirror.json;
        sudo mv ~/chromium_start.sh ~/MagicMirror/PiZero/chromium_start.sh;
        sudo chmod a+x ~/MagicMirror/PiZero/startMagicMirror.sh;
        sudo chmod a+x ~/MagicMirror/PiZero/pm2_MagicMirror.json;
        sudo chmod a+x ~/MagicMirror/PiZero/chromium_start.sh;
        # Use pm2 control like a service MagicMirror
        sudo npm install -g pm2;
        sudo su -c "env PATH=$PATH:/usr/bin pm2 startup systemd -u pi --hp /home/pi";
        pm2 start /MagicMirror/PiZero/pm2_MagicMirror.json;
        pm2 save;
        echo 'Magic Mirror should begin shortly'
        Takes about an hour depending on how up to date your Raspbian image is… I haven’t silenced/run any of the things in the background so you might get a couple of prompts where you just have to press enter (normally during the apt-get upgrade phase)
          rgatlin
          I will give this a try. Thanks for your help!
            andyc7687
            no worries. if you want to have a bit more control over it, you can execute each line of RaspberryPi0.sh (minus the echo requests) directly in the terminal.
              andyc7687 @rgatlin
              @rgatlin Did that work for you?
              if now working, can you mark the post as solved please :)
