    MMM-FRITZ-Box-Callmonitor throws an error after enabling phonebook sync
    4 Posts 4 Posters 3.2k Views 5 Watching
    • K Offline
      kovu94
      Hi there,
      I recently build up a magicmirror2 install on a raspberry Pi Zero W.
      The MM is working and now I’m playing around with modules.
      After installing the MMM-FRITZ-Box-Callmonitor module it shows incoming calls and also call history. But when I activate the phonebook sync it throws me an error on the console:
      Received config for MMM-FRITZ-Box-Callmonitor
      MMM-FRITZ-Box-Callmonitor is waiting for incoming calls.
      Starting access to FRITZ!Box...
      TypeError: PythonShell is not a constructor
          at Class.loadDataFromAPI (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:216:17)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:62:10)
          at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
          at emitTwo (events.js:125:13)
          at Socket.emit (events.js:213:7)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
          at _combinedTickCallback (internal/process/next_tick.js:131:7)
          at process._tickCallback (internal/process/next_tick.js:180:9)
      The config for the module is:
      		module: "MMM-FRITZ-Box-Callmonitor",
      		position: "bottom_left",	// This can be any of the regions. Best results in left or right regions.
      		header: "Letzte Anrufe", // This is optional
      			showContactsStatus: "true",
      			fritzIP: "192.168.178.1",
      			maximumCallDistance: "9999999999",
      			username: "username",
      			password: "password",
      			debug: "true",
      Where can I see the debug informations? On the MM screen I only see this:
      and the sync circle is running without ending.
      The issue occures everytime I reload the MM website.
      During the install of the module I don’t get errors but I’m not that firm with linux to go deeper in the programming.
      Maybe someone can help?
      Thanks,
      kovu94
      • H Offline
        Hein-Jan @kovu94
        @kovu94
        Although I did not have a problem with syncing, (actually I was not getting any call history) my logs gave a similar error.
            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:69:9)
            at emitTwo (events.js:126:13)
            at Socket.emit (events.js:214:7)
            at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
        Looking for the error on internet I found some references to the PythonShell dependency that is being used. It seems that PythonShell is now running at version 1.0.7. Where it was running @ version 0.5.0 during development of the module.
        I have reverted back to 0.5.0 and things are working like they should!
        Go to cd ~/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules.
        Remove the Python-shell directory and all its content:
        rm python-shell -r.
        Now reinstall the old version with:
        npm install python-shell@0.5.0.
        Restart your MagicMirror and it should work.
        Al least it did for me. :smiling_face:
        Hein-Jan
        • Sandy2503S Offline
          Sandy2503
          @kovu94 - You can modify the 3 Files documented here to fix the problem
          Sandy2503
            satsatt
            @sandy2503 said in MMM-FRITZ-Box-Callmonitor throws an error after enabling phonebook sync:
            ted
            I carefully made this corrections you suggested but now got more errors.
            SyntaxError: Unexpected token F in JSON at position 2
                at JSON.parse (<anonymous>)
                at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:358:21)
                at /home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:310:42
                at Array.forEach (<anonymous>)
                at PythonShell.recieveInternal (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:306:15)
                at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:290:21)
                at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:108:18)
                at emitOne (events.js:116:13)
                at Socket.emit (events.js:211:7)
                at addChunk (_stream_readable.js:263:12)
            TypeError: Cannot read property 'indexOf' of undefined
                at PythonShell._endCallback (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:233:25)
                at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:148:39)
                at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_modules/python-shell/index.js:121:13)
                at ChildProcess.emit (events.js:214:7)
                at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
            git show Joseph Bethge 30.oct.2016
