    Synology-Docker-Magicmirror
    22 Posts 3 Posters 13.7k Views 3 Watching
    • O
      OceanK
      Hey!
      I have synology NAS. I would like to run Magic Mirror in docker container. I have some hard time to follow the guide for it.
      could someone tell me step by step what do do? and how do I configure the folder path for installation in the docker for magicmirror.
      best regards Kim
        cyberphox
        Looking for the same…i understand how to search the docker registry to find the image…but unsure after that!
        • O
          OceanK
          yeah I have installed the image but then when Im trying to configure the folder path, thats when I dont know what to do?
          please anyone can help us?
          C 2 Replies Last reply
            cyberphox @OceanK
            @oceank I’m exactly at the same step! hope a guru comes along!!
              cyberphox @OceanK
              @oceank got it running if you need some help!
              O 1 Reply Last reply
              • O
                OceanK @cyberphox
                @cyberphox wow! cool, how?
                  cyberphox
                  some primary info here:
                  https://forum.magicmirror.builders/topic/9120/synology-docker-tutorial/2
                  • O
                    OceanK @cyberphox
                    @cyberphox thanx mate:
                    what about your last part?
                    just need to figure out how to enter the command in shell for it to run
                    after configuring the module in docker , It will autostart as soon as I hit the done button?
                    C 1 Reply Last reply
                      cyberphox @OceanK
                      @oceank i didnt need to enter any commands as it was all done during the setup of the docker container when mapping the drives and port
                      O T 2 Replies Last reply
                      • O
                        OceanK @cyberphox
                        @cyberphox thanx mate!
                        its working , YES!
                          cyberphox
                          im sure the performance is better than running on a Pi
                          • O
                            OceanK @cyberphox
                            @cyberphox hey again!
                            how would this work.
                            the module mmm-voice? so im running mm in docker on synology. I config the file etc.
                            how would I setup the raspberry pi to act as a client, and the pi need to have the mic and speakers etc.
                            because I cannot connect mic and etc to the synology server to pic up the voice…thats all raspberry pi job.
                              cyberphox
                              Was wondering the same thing as I have run some voice stuff on my ubuntu laptop setup…
                              Not sure how it can or would work!
                              • T
                                turuncuoglu @cyberphox
                                @cyberphox I know it is little old but I need some help. I run the docker. It looks like it is starting from the log files. It is looking for config files and uses the default one. But when point the browser to 192.168.xx.xx:8080 nothing happens. What else I need to do? Thanks
                                  cyberphox
                                  Are you able to edit your config file? Might be a whitelist issue.
                                  I know i was having trouble on how to define where my config file and module folder were but figured it out
                                  T 1 Reply Last reply
                                  • T
                                    @cyberphox I know how to get to the config file from synology but I don’t know what I should make it to. Is there one that I should start with?
                                    • T
                                      turuncuoglu
                                      @cyberphox Thaks for the tip. I got it working now. One more question. How do you install new modules?
                                        cyberphox @turuncuoglu
                                        @turuncuoglu i used putty on my windows machine to ssh in and run the commands from there
                                        • T
                                          turuncuoglu
                                          @cyberphox thanks. I found out you can also run it from the container.
                                            @turuncuoglu now if there was a way to run Voice commands from it…
