    Synology-Docker-Magicmirror
    22 Posts 3 Posters 13.3k Views 3 Watching
    • O Offline
      OceanK @cyberphox
      @cyberphox thanx mate:
      what about your last part?
      just need to figure out how to enter the command in shell for it to run
      after configuring the module in docker , It will autostart as soon as I hit the done button?
        cyberphox @OceanK
        @oceank i didnt need to enter any commands as it was all done during the setup of the docker container when mapping the drives and port
        O T 2 Replies Last reply Reply Quote 0
        • O Offline
          OceanK @cyberphox
          @cyberphox thanx mate!
          its working , YES!
            cyberphox
            im sure the performance is better than running on a Pi
            • O Offline
              OceanK @cyberphox
              @cyberphox hey again!
              how would this work.
              the module mmm-voice? so im running mm in docker on synology. I config the file etc.
              how would I setup the raspberry pi to act as a client, and the pi need to have the mic and speakers etc.
              because I cannot connect mic and etc to the synology server to pic up the voice…thats all raspberry pi job.
                cyberphox
                Was wondering the same thing as I have run some voice stuff on my ubuntu laptop setup…
                Not sure how it can or would work!
                • T Offline
                  turuncuoglu @cyberphox
                  @cyberphox I know it is little old but I need some help. I run the docker. It looks like it is starting from the log files. It is looking for config files and uses the default one. But when point the browser to 192.168.xx.xx:8080 nothing happens. What else I need to do? Thanks
                    cyberphox
                    Are you able to edit your config file? Might be a whitelist issue.
                    I know i was having trouble on how to define where my config file and module folder were but figured it out
                    • T Offline
                      @cyberphox I know how to get to the config file from synology but I don’t know what I should make it to. Is there one that I should start with?
                      • T Offline
                        turuncuoglu
                        @cyberphox Thaks for the tip. I got it working now. One more question. How do you install new modules?
                          cyberphox @turuncuoglu
                          @turuncuoglu i used putty on my windows machine to ssh in and run the commands from there
                          • T Offline
                            turuncuoglu
                            @cyberphox thanks. I found out you can also run it from the container.
                              @turuncuoglu now if there was a way to run Voice commands from it…
                              • T Offline
                                @cyberphox Yes that is what I was thinking as well. How do you use yours? Is it a tablet that with a browser?
                                  @turuncuoglu I have a mirror in my bathroom hooked up to a raspberry pi but also access it on a family info board (also running a Pi attached to a tv).
