    Synology-Docker-Magicmirror
    22 Posts 3 Posters 13.7k Views 3 Watching
      cyberphox
      im sure the performance is better than running on a Pi
      O 1 Reply Last reply
      • O
        OceanK @cyberphox
        @cyberphox hey again!
        how would this work.
        the module mmm-voice? so im running mm in docker on synology. I config the file etc.
        how would I setup the raspberry pi to act as a client, and the pi need to have the mic and speakers etc.
        because I cannot connect mic and etc to the synology server to pic up the voice…thats all raspberry pi job.
          cyberphox
          Was wondering the same thing as I have run some voice stuff on my ubuntu laptop setup…
          Not sure how it can or would work!
          • T
            turuncuoglu @cyberphox
            @cyberphox I know it is little old but I need some help. I run the docker. It looks like it is starting from the log files. It is looking for config files and uses the default one. But when point the browser to 192.168.xx.xx:8080 nothing happens. What else I need to do? Thanks
              cyberphox
              Are you able to edit your config file? Might be a whitelist issue.
              I know i was having trouble on how to define where my config file and module folder were but figured it out
              T 1 Reply Last reply
              • T
                @cyberphox I know how to get to the config file from synology but I don’t know what I should make it to. Is there one that I should start with?
                • T
                  turuncuoglu
                  @cyberphox Thaks for the tip. I got it working now. One more question. How do you install new modules?
                  C 1 Reply Last reply
                    cyberphox @turuncuoglu
                    @turuncuoglu i used putty on my windows machine to ssh in and run the commands from there
                    • T
                      turuncuoglu
                      @cyberphox thanks. I found out you can also run it from the container.
                        @turuncuoglu now if there was a way to run Voice commands from it…
                        • T
                          @cyberphox Yes that is what I was thinking as well. How do you use yours? Is it a tablet that with a browser?
                            @turuncuoglu I have a mirror in my bathroom hooked up to a raspberry pi but also access it on a family info board (also running a Pi attached to a tv).
