    Unable to sendSocketNotification from node_helper to Module
    5 Posts 2 Posters 4.2k Views 2 Watching
      jc21
      Hi community, I’m pulling my hair out trying to get this one working.
      I’ve got my MMM-IFTTT module nearly completed, except for a small hickup.
      In the node_helper.js I’m sending a socket notification that is not getting through to the UI. It was working at some stage before nesting it in another function, so I assume it’s a scope issue. I’ve tried debugging everything everywhere, even using this.io to send it the hard way.
      I’m using the new ES6 anonymous function syntax, ie:
      this.expressApp.post('/IFTTT', (req, res) => {
      which should keep the this reference from outside of the function and all my console logging suggests it does, however I think that the io reference is not the same one somehow, and despite the this.io.of(this.name).emit(notification, payload); succeeding in the node helper library, the notification simply doesn’t show in the UI dev console.
      This is also apparent when trying the var self = this; method, using the self object even immediately doesn’t send through the socket.
      Any help on this scope stuff would be appreciated! Thanks in advance.
      Raspbian Jessie
      Node version: v6.6.0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @jc21
        @jc21 did you try the common way?
        this.sendSocketNotification('MSG', 'Hello World');
        and in the module itself
        socketNotificationReceived: function(notification, payload){
            if(notification === 'MSG'){
                Log.info(payload);
          jc21
          I dumbed the module right down:
          node_helper.js
          const NodeHelper = require('node_helper');
              start: function() {
                  console.log('[IFTTT] Starting node_helper');
                  var self = this;
                  setTimeout(function () {
                      self.sendSocketNotification('MSG', {message: 'test'});
                  }, 10000);
          MMM-IFTTT.js
                  if (notification === 'MSG'){
                      Log.info(payload);
          Still not getting the log in dev console :(
            @jc21 If I’m right you must start the connection from the module, but can’t test it right now
            MMM-IFTTT.js
            start: function() {
                    this.sendSocketNotification('START', {message: 'start connection'});
                        Log.info(payload);
            node_helper.js
                start: function() {
                    if (notification === 'START'){
                        setTimeout(() => {
                            this.sendSocketNotification('MSG', {message: 'test'});
                         }, 10000);
              jc21
              Wow that is not obvious or documented.
              However, that worked :) Thanks heaps!
