    Cannot start after reboot?
    4 Posts 4 Posters 1.2k Views 2 Watching
      Smedegaard
      I cannot start the MagicMirror after reboot. When i type:
      pm2 start MagicMirror
      I get the following error:
      [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
      [PM2] PM2 Successfully daemonized
      [PM2][ERROR] script not found : /opt/aiy/projects-python/MagicMirror
      UPDATE:
      I did an update and now it tells me that it is starting MagicMirror but it does not show after reboot or when entering:
      I just get the following lines:
      pi@raspberrypi:~/AIY-projects-python $ pm2 start MagicMirror [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] [MagicMirror](0) ✓
      [PM2] Process successfully started
      │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory │
      │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 18  │ 0%     │ 13.7 MB   │
        AxLed Module Developer
        @Smedegaard
        Can you please post the output of
        tail -f ~/.pm2/logs/MagicMirror-out-0.log
        and
        tail -f ~/.pm2/logs/MagicMirror-error-0.log
        AxLED
        • bheplerB Offline
          bhepler Module Developer @AxLed
          @axled - The -f flag on the tail command will continually follow along with the log file as it gets updated. It may be difficult to capture the logs for copy & paste if they’re continually updating.
          I would recommend tail -30 ~/.pm2/logs/MagicMirror-out-0.log which will give you the last 30 lines of the log files.
            rts58
            Not sure why, but on my install these files are called mm-out.log and mm-error.log. So maybe it would be
            tail -30 ~/.pm2/logs/mm-out.log
            and
            tail -30 ~/.pm2/logs/mm-error.log
