    Default Calendar // Multiple caldendar instances overwritting each other..(maximumNumberOfDays)
    7 Posts 3 Posters 2.9k Views 5 Watching
      bolish
      Hi there,
      I don’t exactly what I’m doing wrong or if the issue comes from the module itself.
      My issue :
      I’m running 3 instances of the default calendar.
      In some case, the 3 calendars instances are pointing to the same calendars URL, nevertheless, I want the 3 instances to have a different “maximumNumberOfDays” config.
      The “maximumNumberOfDays” of instance 1 is overwritten by the 2 second instance settings, and so on…Making my wish to have different setups impossible as all the 3 instances are using same “maximumNumberOfDays”.
      You will find my code hereunder, help would be highly appreciated!!
      			disabled: false,
      			header: "Aujourd'hui",
      				timeFormat: "absolute",
      				maximumNumberOfDays: 1,
      				excludedEvents: [],
      						// Anniversaires
      						symbol: "birthday-cake",
      						url: "https://1.ics",
      						// Calendrier Fabrice
      						symbol: "calendar-check",
      						url: "https://2.ics",
      						// Calendrier Audrey
      						symbol: "calendar-check-o",
      						url: "https://3.ics",
      						// Calendrier Férié
      						symbol: "flag",
      						url: "https://4.ics",
      						// Vacances Scolaires
      						symbol: "sun",
      						url: "http://www.5.ics",
      						// Repas
      						symbol: "utensils",
      						url: "https://6.ics",
      			disabled: true,
      			header: "Demain",
      				maximumNumberOfDays: 2,
      				excludedEvents: [],
      						// Anniversaires
      						url: "https://2",
      						// Calendrier Férié
      						symbol: "flag",
      						symbol: "sun",
      						url: "http://5.ics",
      						// Repas
      						symbol: "utensils",
      			disabled: false,
      			header: "Evénements à venir",
      				maximumNumberOfDays: 62,
      				excludedEvents: ["Poney"],
      						// Anniversaires
      						//maximumNumberOfDays: 62
      						// Calendrier Férié
      						symbol: "flag",
      						symbol: "sun",
      NOTE : it seems that the issue was already pointed out on Github, and MichMich even stating that this could be easy to solve, but I clearly have no clue how…
      GitHub Issue #1109
      Anyway, really hope someone could support my need…
      Thanks in advance
        bolish
        well… I believe it’s far from being perfect…but at least it seems to do the job…
        I created a “new” module which does exactly same / has the same code as the one I want to use, but has a different name (folder named “MMM-Calendar2” -> file named “MMM-Calendar2.js” -> within the line Module.register(‘MMM_Calendar2’)).
        Not in the default module folder but into the 3rd party module folder…
          sdetweil @bolish
          @bolish did u change something from the original?
            bolish
            no… just copy paste, renaming.
              sdetweil @bolish
              @bolish so, are you running BOTH calender modules, default and your ‘new’ one?
                bolish
                yes indeed.
                • H Offline
                  hiesscher
                  Some additional Information:
                  In calendarfetcher.js and nodehelper.js is the following line:
                  const Log = require("../../../js/logger.js");
                  If you copy the “calendar” folder down to “modules” this reference will be broken.
                  So you have to change to:
                  const Log = require("../../js/logger.js");
