    Back to Booting to black
    13 Posts 2 Posters 5.0k Views 2 Watching
      dwleo @sdetweil
      pi@raspberrypi:~ $ npm start dev
      npm ERR! missing script: start
      That’s what I got.
        sdetweil @dwleo
        @dwleo well, you have to be IN the MM folder
        cd MagicMirror
        D 1 Reply Last reply
          dwleo @sdetweil
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘moment-timezone’
          D S 2 Replies Last reply
            dwleo @dwleo
            Sometimes I feel like a real noob. Anyway the config.js file is there right where it always has been.
              sdetweil @dwleo
              @dwleo
              from the MM folder run
              node tests/configs/check_config.js
              and work thru the errors from top to bottom
              rerunning as needed
                sdetweil @dwleo
                @dwleo yes, but there is a syntax error from all the editing you have done
                make a rule,
                1 change at a time,
                AND save the working config.js before u edit
                  dwleo @sdetweil
                  Yeah, you are right. (sigh)
                  Anyway I ran it and got this:
                  pi@raspberrypi:~/MagicMirror $ node tests/configs/check_config.js
                  Checking file… /home/pi/MagicMirror/config/config.js
                  Your configuration file doesn’t contain syntax errors :)
                    sdetweil @dwleo
                    @dwleo ok, then you have a module name wrong, or u deleted it
                    OR, you installed a module, but didn’t finish ITS install, by going to ITS folder and running npm install
                    when a module uses other modules, (some not used by base MM), you have to do a manual step to install ITS dependencies
                    so, I would look thru the modules u might have just installed, and edit the package.json file in each and look for moment-timezone… if its there, then u probably need to run npm install in that folder
                    D 2 Replies Last reply
                      dwleo @sdetweil
                      Thank you. I will try that.
                        dwleo @sdetweil
                        Hurray!
                        That did it. I must have used my ‘fat fingers’ when in the MMM-NHL file.
                        Thanks so much!
                          sdetweil @dwleo
                          @dwleo no problem… thanks for letting us know… the system is sensitive in certain spots!
                          can u mark your issue resolved?
