    MMM-google-route Example ?
    14 Posts 4 Posters 8.6k Views 4 Watching
      bleusswissbless
      Hi guys :)
      I’m trying to configure MMM-google-route on my mirror. I tried to follow step and google link but, hmm, I don’t f*** understand anything about how it works :D
      Am I such a noob ? :) I coudldn’t found anything about this module on the forum. I need at list a sample configuration for origin and destination parameters. If someone could share something !? thanks guys :)
      • V Offline
        Valkilane
        This is what i’ve done to get it up and running:
        active the google api’s: (sign-up, follow the path mentioned in the short description provided by the module)
        activated APIs:
        Directions API (if I disable it nothing works anymore)
        Geocoding API
        Maps JavaScript API
        then add this to your config.js:
                    module: 'MMM-google-route',
                    position: 'bottom_left',
                        height: '150px',
                        width: '300px',
                        key: 'your-google-apikey',
                        directionsRequest:{
                            origin: 'city country',
                            destination: 'city country'
        Hope this works, did for me!
        F 1 Reply Last reply Reply Quote 1
          bleusswissbless
          it was so simple ! :D
          i tried with “Address city country” for both origin and destination field… it works !! I think manual could be more precise on this point. Thank you very much @Valkilane
          • F Offline
            FruityBebbles @Valkilane
            @Valkilane Hi, I know this is a bit old but what if you wanted to be more specific because the origin and the destination are both located in the same city…
            Im trying to use my address as the origin and a well known hospital in the city as the destination…
            my config is
            module: "MMM-google-route",
            		key: "google api-key",
            		directionsRequest:{
            		origin: "address, city, country",
            		destination: "lat", "lng", // can't figure out...
            		height: "400px",//default=300px
            		width: "400px",//default=300px
            		avoidTolls: true,
            		showAge: false,
            		fontSize: "80%",
            Do you know what order I have to put the coordinations in, so i can get this to work?
              sdetweil @FruityBebbles
              @FruityBebbles looks like the doc for the module references a google doc with says
              directionsRequest	Required The directions to show on the map.
              Type: google.maps.DirectionsRequest interface
              direction request link takes you here
              https://developers.google.com/maps/documentation/javascript/reference/directions#DirectionsRequest
              which says LatLng or LatLngLiteral
              https://developers.google.com/maps/documentation/javascript/reference/coordinates#LatLngLiteral
              which both show as this
              {lat: -34, lng: 151}
              so
              		directionsRequest:{
              		destination: {"lat": number, "lng":number}, // can't figure out...
              		avoidTolls: true,
              		showAge: false,
              		fontSize: "80%",
              • F Offline
                FruityBebbles @sdetweil
                @sdetweil Thankyou for laying it out for me! I was trying to put
                 destination: [lat: number,  lng: number]
                instead of
                destination: {"lat": number,  "lng": number},
                • I didn’t know to add the “” or the {}
                now, my config looks like:
                		directionsRequest:{
                		avoidTolls: true,
                		showAge: false,
                		fontSize: "80%",
                I am getting a 400px by 400px box showing up in the “top_left” of my mirror, but now it’s all white with no map being shown…
                  @FruityBebbles said in MMM-google-route Example ?:
                  origin: “address, city, country”,
                  you of course set a good start point (origin) with the real location, right?
                  a good lat/lng near me is { “lat”: 31.4490047,“lng”:-98.6031736}
                  • F Offline
                    FruityBebbles
                    yes… I should have said that my origin is the lat/lng
                    origin: {"lat": , "lng": }
                    and my destination is the
                    but to make things more translucent, here’s my config:
                    	key: "api-key",
                    	directionsRequest:{
                    		origin: {"lat": 40.0583287, "lng": -75.0074246},
                    		destination: "3401 Civic Center Blvd, Philadelphia, US",
                    			avoidTolls: true,
                    			showAge: false,
                    			fontSize: "80%",
                      @FruityBebbles please use code blocks
                      anyhow, try this lat/lng for your destination
                      39.9487306,-75.1965791
                      i don’t know anything about this module
                      • F Offline
                        @sdetweil said in MMM-google-route Example ?:
                        I thought I did… my bad
                        I did, but no change…
                        hahah could have fooled me =)
                        but no, you’ve gotten me closer to having this work than I have on my own so I thank you a lot.
                        • F Offline
                          FruityBebbles @FruityBebbles
                          @FruityBebbles @sdetweil
                          Just thought you should know that it works now…
                          For some reason
                          height: "any sized px",
                          width: "any sized px",
                          showAge: true/false,
                          fontSize:  80%
                          …were all the issues-- not sure why but I figured I’d let anybody who may be reading this know that you should make sure to get your coordinates or whatever “right,” then deal with the fancy stuff, like fontSize and stuff… fwiw
                            @FruityBebbles but I don’t understand how this is different than what you had before
                            		showAge: false,
                            		fontSize: "80%"
                            • F Offline
                              ok, so it turns out that those four are supposed to be outside of the directionsRequest: {} parameters.
                              While I had my config as
                              	key: "api-key",
                              	**directionsRequest:{**
                              		*height*: "400px",//default=300px
                              		*width*: "400px",//default=300px
                              		avoidTolls: true,
                              		*showAge*: false,
                              		*fontSize*: "80%",
                              I had to move those four out, which made my config:
                              	*height*: "300px",
                              	*width*: "300px",
                                      *showAge*: false,
                                      *fontSize*: "80%",
                              	key: "api-key",
                              		destination: {"lat": 39.9487306, "lng": -75.1965791},
                              		avoidTolls: true,
                              the height, width, etc were all in the wrong place-- to me…
                                @FruityBebbles ah, now i have it… yes they have nothing to do with direction to/from
