Unsolved some modules are not showing on screen
try
npm start dev
select the console tab of the developers window
scroll to find any red text, which are errors…another user just had a similar problem, which turned out to be some file system problem on his memory card.
hm ok. I am on console (ssh).
So I have to work on the Pi directly with GUI to check that, right? -
@stephen yes
Sorry, but, dont know how to do that o.O feel like a noob
I’ve used VNC to get the GUI, but where to find the dev window? I’ll started from the terminal/console.
@stephen no idea over vnc…
attach a mouse to the pi…
Its the same like a mouse connected. Sure I can connect a monitor and mouse+keyboard, but I dont know how to get to the dev window. I dont coded anything on the pi directly (like I am using visual code at windows for example). So how to get the dev-output?
@stephen on your remote console, do
ssh to the pi, no gui
cd MagicMirror export DISPLAY=:0 npm start dev
and, of course, you need a monitor on the PI
Thanks!
I’ve connected a monitor and keyboard. Connected via ssh and started like you’ve posted.Uh great output. Never seen :) … but I am not a node-nerd yet. Anyway…
There are errors to the modules I’ve missing.
In every case there is an error loading the skripts. In the log I saw there is a “/” too much while executing. For example:
GET http://0.0.0.0:8080/modules/internet-monitor//internet-monitor.js
Same at the other modules. But why? Where to correct this?
Oh I saw its on all the paths (the running also).
But the error at all the modules areERROR on loading script XYZ
The scripts are in the given folder.
@stephen a file system problem again.
U need to run fsck , the Unix chkdsk.
But u can’t run on the boot drive while system is running …Google search ‘fsck raspberry pi’
I have another Linux system i can use.
