    some modules are not showing on screen
    23 Posts 5 Posters 8.0k Views 5 Watching
      try
      npm start dev
      select the console tab of the developers window
      scroll to find any red text, which are errors…
      another user just had a similar problem, which turned out to be some file system problem on his memory card.
        A Former User
        hm ok. I am on console (ssh).
        So I have to work on the Pi directly with GUI to check that, right?
          sdetweil @Guest
          @stephen yes
            A Former User
            Sorry, but, dont know how to do that o.O feel like a noob
            I’ve used VNC to get the GUI, but where to find the dev window? I’ll started from the terminal/console.
              sdetweil @Guest
              @stephen no idea over vnc…
              attach a mouse to the pi…
                A Former User
                Its the same like a mouse connected. Sure I can connect a monitor and mouse+keyboard, but I dont know how to get to the dev window. I dont coded anything on the pi directly (like I am using visual code at windows for example). So how to get the dev-output?
                  sdetweil @Guest
                  @stephen on your remote console, do
                  ssh to the pi, no gui
                  cd MagicMirror
                  export DISPLAY=:0
                  npm start dev
                  and, of course, you need a monitor on the PI
                    A Former User
                    Thanks!
                    I’ve connected a monitor and keyboard. Connected via ssh and started like you’ve posted.
                    Uh great output. Never seen :) … but I am not a node-nerd yet. Anyway…
                    There are errors to the modules I’ve missing.
                    In every case there is an error loading the skripts. In the log I saw there is a “/” too much while executing. For example:
                    GET http://0.0.0.0:8080/modules/internet-monitor//internet-monitor.js
                    Same at the other modules. But why? Where to correct this?
                      A Former User
                      Oh I saw its on all the paths (the running also).
                      But the error at all the modules are
                      ERROR on loading script XYZ
                      The scripts are in the given folder.
                        sdetweil @Guest
                        @stephen a file system problem again.
                        U need to run fsck , the Unix chkdsk.
                        But u can’t run on the boot drive while system is running …
                        Google search ‘fsck raspberry pi’
                        I have another Linux system i can use.
