    some modules are not showing on screen
    23 Posts 5 Posters 7.6k Views 5 Watching
      A Former User
      Hey there.
      I didnt find a post with a solution for me. I’ve installed MM well and it displays the default stuff. I’ve added some modules, always like written at its description with git clone etc. Sometimes it was necassary to npm install
      Now, when I restart using npm start MM starts well. No “config-errors”. I can see in the console the modules loaded well, but… they are not at the monitor. I’ve played with the regions without success.
      I’ve already updated everything. Senseless because everything was brand new installed 2 days ago. But anyway, I tried it.
      I cant belive all these modules are broken or outdated etc. May someone has an idea. I am also using the MMM-Admin-Interface for an easier handling.
      I’ll give you my config.js…
      The following modules are NOT showing: email, fuel (throws error in cli with “no data”, verified key on webpage etc), internet-monitor, email, MMM-Census.
      Just to be clear: MM is running fine, no errors, showing the screen with SOME modules.
        "port": 8080,
        "language": "de",
        "timeFormat": 24,
        "units": "metric",
        "modules": [
            "module": "alert"
            "module": "MMM-News",
            "position": "bottom_bar",
            "config": {
              "apiKey": "MYSECRET",
              "type": "horizontal",
              "query": [
                  "sources": "hacker-news, national-geographic, bild, cnn, focus, reddit-r-all"
                  "country": "de",
                  "className": "redTitle"
              "items": 1,
              "touchable": false,
              "autoscroll": true,
              "drawInterval": 10000
            "module": "MMM-Admin-Interface"
            "module": "updatenotification",
            "position": "top_bar"
            "module": "clock",
            "position": "top_left"
            "module": "compliments",
            "module": "currentweather",
            "position": "top_center",
            "config": {
              "location": "Lohr am Main",
              "locationID": "2876147",
              "appid": "MYSECRET"
            "module": "weatherforecast",
            "position": "top_right",
            "config": {
              "appid": "MYSECRET"
            "header": "Wetter die Tage in "
            "module": "MMM-Fuel",
            "lat": 50.036101,
            "lng": 9.642108,
            "types": "diesel",
            "api-key": "MYSECRET",
            "provider": "tankkoenig",
            "rad": 10,
            "sort": "dist"
            "module": "internet-monitor",
            "header": "Internet",
            "config": {
              "maxTime": 20000,
              "updateInterval": 100,
              "verbose": true,
              "displayStrength": true,
              "displaySpeed": false,
              "strengthIconSize": 80,
              "maxGaugeScale": 100
            "module": "email",
            "position": "top_left",
            "header": "Emails",
            "config": {
              "accounts": [
                  "user": "info@survive-yourself.de",
                  "password": "MYSECRET",
                  "host": "MYSECRET",
                  "port": 993,
                  "tls": true,
                  "numberofEmails": 3,
                  "authTimeout": 10000
            "fade": true,
            "maxCharacters": 30
            "module": "MMM-Census",
            "header": "Population",
            "position": "middle_center",
            "config": {
              "country": "World",
              "popYear": 2018,
              "useHeader": true,
              "header": "Popo",
              "maxWidth": "300px",
              "animationSpeed": 3000,
              "rotateInterval": 60000
        "address": "0.0.0.0",
        "ipWhitelist": [
          "127.0.0.1",
          "::ffff:127.0.0.1",
          "::1",
          "192.168.178.1/24",
          "::ffff:192.168.178.1/24"
      • justjim1220J Offline
        justjim1220 Module Developer @Guest
        @stephen
        try rebooting your system
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          A Former User
          Thanks for your answer, but of cause (didnt say - I know) - already rebooted .(
          Anyway, rebooted again - no effect.
          I also stopped the autostart with pm2 stop mm before to prevent a double runnig MM o.O.
          No effects anyway.
            try
            npm start dev
            select the console tab of the developers window
            scroll to find any red text, which are errors…
            another user just had a similar problem, which turned out to be some file system problem on his memory card.
              A Former User
              hm ok. I am on console (ssh).
              So I have to work on the Pi directly with GUI to check that, right?
                sdetweil @Guest
                @stephen yes
                  A Former User
                  Sorry, but, dont know how to do that o.O feel like a noob
                  I’ve used VNC to get the GUI, but where to find the dev window? I’ll started from the terminal/console.
                    sdetweil @Guest
                    @stephen no idea over vnc…
                    attach a mouse to the pi…
                      A Former User
                      Its the same like a mouse connected. Sure I can connect a monitor and mouse+keyboard, but I dont know how to get to the dev window. I dont coded anything on the pi directly (like I am using visual code at windows for example). So how to get the dev-output?
                        sdetweil @Guest
                        @stephen on your remote console, do
                        ssh to the pi, no gui
                        cd MagicMirror
                        export DISPLAY=:0
                        npm start dev
                        and, of course, you need a monitor on the PI
