    Magic Mirror modul position
    2 Posts 2 Posters 3.8k Views 3 Watching
    • F
      freakycasey
      Hello there!
      so i’ve just set up my Magic Mirror. The Problem i have now is, that i want my modules to be on the edge of my display without the little blank/black space between Screen-Edge and Module (red line in my Screenshot).
      alt text
      These are the default positions for all the modules:
      https://forum.magicmirror.builders/topic/286/regions
      And in this they are saying you could change the positon in ~/MagicMirror/css/custom.css, but how do i do that?
      https://forum.magicmirror.builders/topic/624/change-module-position/3
      http://www.offshorededicated.net
      I would be happy to get some advice.
      Thanks (:
        bolish
        You can adjust the full MM body border into the custom.css file.
        (/MagicMirror/css/custom.css)
        like that (play with the values until you’re happy) :
        body {
          margin: 20px;
          height: calc(100% - 40px);
          width: calc(100% - 40px);
        You should maybe also check the settings of your screen itself (depending if you have that issue outside MM or not).
