    MM Error - .AppleDouble and UnhandledPromiseRejectionWarning
    34 Posts 4 Posters 18.5k Views 3 Watching
    • lavolp3L
      lavolp3 Module Developer @bolish
      @bolish First, try another one
      find . -maxdepth 2 -exec grep -nwl  .then 2>/dev/null {} +
      Promises are not always processed by a Promise function, but I also by calling something and then calling .then().
      Actually I know these bastards for two or three days now, so I’m far from being an expert
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        bolish
        @lavolp3
        thx
        Here is the result
        pi@MagicPi:~/MagicMirror/modules $ find . -maxdepth 2 -exec grep -nwl  .then 2>/dev/null {} +
        ./MMM-Remote-Control/node_helper.js
        ./MMM-Remote-Control/installer.sh
        ./MMM-BackgroundSlideshowInfo/README.md
        ./MMM-NotificationTrigger/README.md
        So… Remote Control I believe…
        I will try to disable it and see what happens.
        lavolp3L 1 Reply Last reply
          bolish
          I confirm…
          No error message anymore after disabling MMM-RemoteControl.
          Wao…and now?? Do you have a clue about next step or should I raise an issue into MMM-ControlRemote git?
          • lavolp3L
            @bolish That’s odd. Something doesn’t add up, sorry. I think a “then” is searched as well. But try these modules.
            If not successfull you’d need to go with disabling one module after another
            • lavolp3L
              @bolish Well, great!! BUt oddly, I dont have this… and I have the module as well.
              Do you have Jopyth’s original version installed? Or a fork?
                bolish
                @lavolp3
                I have the original version from Jopyth.
                S***, I hoped it would have been easier to figure out!!
                I just Git Pulled… Was already up to date
                • lavolp3L
                  @bolish OK I can confirm your errors. Had it disabled. By enabling the unhaldled promises come up.
                  Raise an issue. I’ll have a look at the code
                    bolish
                    Don’t you think it can be linked to the .appledouble thing. Remember that :
                    2019-02-15T22:45:59  Launching application. (/home/pi/MagicMirror/js/electron.js:82 App.)
                    2019-02-15T22:45:59  ERROR! Could not find main module js file for .AppleDouble (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:258 Class.loadModuleDefaultConfig)
                    2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                    2019-02-15T22:46:03  (node:6793) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                    2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                    2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                    2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                    2019-02-15T22:46:04  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                    2019-02-15T22:46:08  MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                    Because the .appledouble error is refering to Remote Control also.
                    So…you just have the same issue now but never noticed it before?
                    lavolp3L 2 Replies Last reply
                    • lavolp3L
                      @bolish No.
                      Unhandled promise rejections are code stuff that can be overcome quite easily.
                      Think of it like this.
                      You ask your program to do something outside (e.g. request data from somewhere else.
                      When it doesn’t work the “promise” of delivering something is rejected.
                      When this rejection is unhandled (the program isnt told what to do) you get this error
                      B 1 Reply Last reply
                      • lavolp3L
                        @bolish said in MM Error - .AppleDouble and UnhandledPromiseRejectionWarning:
                        May have been updated in the past. Don’t know.
                          bolish @lavolp3
                          @lavolp3
                          Thanks for explanation.
                          I’ve just raised it on Git on an existing issue log.
                          • lavolp3L
                            The issue is already raised
                            https://github.com/Jopyth/MMM-Remote-Control/issues/87
                            And the solution si down below:
                            “It’s this line: var baseUrl = result[0].refs.fetch; for some modules it looks like simple-git fails. Adding a try catch block for it in my PR.”
                              bolish
                              Just to be sure. I didn’t noticed any real effect of this issue.
                              I was mainly trying to solve it before I’m experiencing stability issues with MMM-GroveGestures and wanted to be sure that this “promise” thing is not the root cause before raising the MMM-GroveGestures issue.
                              Do you think that it is now clear that my MMM-GroveGestures issue and this one are not linked (meaning I can look at the GroveGesture issue in parallel)
                                bolish @lavolp3
                                @lavolp3
                                OK, I will try the fix
                                • lavolp3L
                                  @bolish This error/notice is solely within the Remote-Control module and not related to any other module. It does not influence your mirror performance at all.
                                  If you can ignore it (which I couldnt), you might as well do.
                                    bolish
                                    OK, thanks for your support in that!
                                    Now let’s move to the next issue…MMM-GroveGestures…(I will open a second post for that).
                                    After those one are fixed, my MM will be nearly perfect and will be very close to use it in real life!!!
                                    • lavolp3L
                                      I haven’t really been for two years. Lol.
                                        bolish @lavolp3
                                        @lavolp3 :-)
                                        Let’s see what will happen to mine then!! But to be honest, I’m also afraid that this is the kind of things which is never really “finished”…
                                        Who cares…As soon as we enjoy??
                                        (the issue then becomes the quantity of unfinished things…)
