    MMM-GoogleAssistant, segmentation fault!
    6 Posts 3 Posters 3.3k Views 3 Watching
      roxx
      Hello friends, i m installing GA module as given in its readme file at MMM-GoogleAssistant
      i am installing this GA Module and i am stuck at “Run the Sample Code” … i followed the readme file and when i enter the command “googlesamples-assistant-hotword --project-id my-dev-project --device-model-id my-model” in the terminal, it says “Segmentation fault”
      i tried different id’s and stuff, searched but i got no luck… more over its bit confusing with model id, device model id, project id, etc … i have Magic Mirror running fine with default modules… Please help me out with this! Thanks.
      see the error,  segmentation fault
      Only a biker knows why dogs stick their head outside the window of a moving vehicle!!
        roxx
        still no success, do i need to install MMM-Hotword…?? i havent came across anything in its readme like that… just asking…
          radokristof
          use MMM-AssistantMk2. It is a newer version, maybe this is not supported.
          From the Github page: “(Deprecated) This project is not supported any more from original owner. Use alternative MMM-AssistantMk2”
            roxx @radokristof
            @radokristof said in MMM-GoogleAssistant, segmentation fault!:
            Thanks, will try this mk2 module…
              A Former User @roxx
              @roxx
              MMM-GoogleAssistant is not mine. :D it is nothing related with MMM-Hotword or MMM-AssistantMk2 (or even deprecated MMM-Assistant)
              Anyway if you have a problem on installation or usage, leave an issue on github. I’ll support.
                roxx @Guest
                @sean said in MMM-GoogleAssistant, segmentation fault!:
                @roxx
                yep, i have submitted an issue, issue #56. thanks.
