    issue with installing MMM-awesome-alexa
    15 Posts 5 Posters 7.3k Views 5 Watching
      jmartin1009 @sdetweil
      @sdetweil is there anything i can do? Or does that mean that i wont be able to use the MMM-awesome-alexa module altogether? I want Alexa integration and voice control and i had decided to use it because i read good things on here about it but if i have to use another due to it just flat out not working with the Pi or something then I would be open to suggestions for other ones to use. But if possible, it would be preferred to use awesome-alexa as it sounds like a good module. Thanks in advance! You’re always very helpful and i really appreciate it!
        sdetweil @jmartin1009
        @jmartin1009 i don’t know, but am trying to recreate your experience
        J 1 Reply Last reply
          @sdetweil okay! Let me know if anything happens to yours or if you figure anything out, or I mean even if you find out it doesn’t work haha thanks!
            @jmartin1009 still having problems building snowboy… have a trip out of town til tomorrow night… will have to get back to it then
              sonicgoose
              I was just about to go home and try installing this module. Glad I looked here first! Not sure I’ll bother now…
                @sdetweil that’s perfectly fine, thanks for you help! Do you have any suggestions for other good voice control ones to try that are either similar to this one or have better capabilities? I saw mirrormirroronthewall but that one sounds really hard to use and I’m not sure I need that much. Would be open to using Google Assistant. Is there any I can use to control music? I have an iPhone and use Apple music and have it on my Pi with Shairport-sync, so if there is one that can control music that would be absolute perfection!! If not, I’m open to other suggestions as this one doesn’t seem to want to work. Thanks!
                  jmartin1009 @sonicgoose
                  @sonicgoose you might have fine luck with it, but mine fails over and over during the install and @sdetweil seems to be having the same issue. I would say give it a try and if it works, awesome. If it doesn’t, maybe take a look at some other voice control modules. If anyone finds a fix I will be sure to tag you if you also aren’t able to get it to work, if you try it that is. Good luck! Let me know if yours works!
                  D 1 Reply Last reply
                    dmwilsonkc @jmartin1009
                    @jmartin1009 I am using Mycroft. Great open source AI and I created a skill to control the Mirror that requires the MMM-Remote-control module. It can be installed on the same RPi but works much snappier on a separate RPi.
                    You can see a video and instructions Here
                    Not sure if you are interested in an open source assistant, but this one works well.
                      @jmartin1009 I have not made any real progress… not sure why yet
                        @sdetweil that’s alright, I decided to go with Google Assistant, thanks for your help! I do still need some help with getting that to work though, as I stated in my other post! Thanks!
