MMM-AssistantMk2 and auth_and_test.js
Reposting because I put this in the wrong forum the first time.
I’ll try to make a long story short:
Installed MMM-AssistantMk2 and MMM-Hotword. Added default config for both to config.js. Got nothing but a black screen. Narrowed the problem down to MMM-AssistantMk2 and grpc. So went through the troubleshooting tips to switch to grpc-js instead (same problem) and to downgrade to v1.13 of grpc. I’ve now (for the third time) created my credentials.json file and am trying to run
node auth_and_test.jsThis is what shows up after a few seconds:
/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/auth.js:27 const oauthClient = new OAuth2(key.client_id, key.client_secret, key.redirect_uris[0]); ^ TypeError: Cannot read property 'client_id' of undefined at new Auth (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/auth.js:27:38) at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js:21:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/auth_and_test.js:60:19) at Module._compile (internal/modules/cjs/loader.js:654:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10) at Module.load (internal/modules/cjs/loader.js:566:32) at tryModuleLoad (internal/modules/cjs/loader.js:506:12) at Function.Module._load (internal/modules/cjs/loader.js:498:3) at Function.Module.runMain (internal/modules/cjs/loader.js:695:10) at startup (internal/bootstrap/node.js:201:19)And I’m stuck. Help?
@sonicgoose
Your credentials.json is wrong. Especially you’ve missed or failed something on making credentials on google console -
@Sean I don’t think so. I got it to work twice. My browser launched, I logged in, I got a code back and paste that into the prompt presented by auth_and_test.js. Twice. Now the third time, after downgrading grpc to v1.13, it won’t work and I get the above error.
@sonicgoose
Weird, because it is not related grpc. error log says your credentials.json has been corrupted or missing something.Open your
credentials.jsonand look into it.{"installed":{"client_id":"377258677000-2rv97u3b2....It should seems similar with above.
Your file might have other text instead"installed". Isn’t it? -
@sean My file starts with
{"web":{"client_id":"10236352... -
@Sean This is weird. I just downloaded my credentials again and this time got
{"installed":{"client_id":"1023635200...I’ll try this again when I get home. No idea how it could have changed.
SUCCESS!!
