Motion Detector and OSX
6 Posts 2 Posters 1.1k Views 2 Watching
  • 0 Offline
    0v3rNuLL
    hi everyone!
    I succesfully run MM2 on a macmini late 2009. Currently im testing some modules and so far so good except for one module Motion detector. I was looking on the code on node_helper.js and found the line with the command “vcgencmd display_power 0”.
    In OSX not work but “pmset displaysleepnow” to put the screen on sleep does the trick and " caffeinate -u -t 1" to wake up.
    So i replace the command
    if (result) {
    				exec("vcgencmd display_power 0", function(err, out, code) {
    					if (err) {
    						console.error("MMM-MotionDetector: error deactivating monitor: " + code);
    					} else {
    						console.log("MMM-MotionDetector: monitor has been deactivated");
    to
    if (result) {
    				exec("pmset displaysleepnow", function(err, out, code) {
    					if (err) {
    					} else {
    Its looks like work but im getting this message on console log “pmset displaysleepnow blocked by app electron.js” and the screen keeps alive.
    Is there a way to solve this?
    Or maybe toggling the body to hide to get the black screen?
    Thanks in advance and sorry for my bad english :)
    • S Away
      @0v3rNuLL said in Motion Detector and OSX:
      there is an npm module to work around that it appears
      https://electronjs.org/docs/api/power-save-blocker
      0 1 Reply Last reply Mar 17, 2019, 3:24 AM Reply Quote 1
      • 0 Offline
        0v3rNuLL
        hi sdetweil!
        I try on node_helper.js located on MMM-MotionDetector at the begining and did not work still getting display slep prevented by electron
        here is the part i change
        //////Original code/////
        const NodeHelper = require("node_helper");
        const exec = require("child_process").exec;
        const { powerSaveBlocker } = require('electron');
        const id = powerSaveBlocker.start('prevent-app-suspension');
        console.log(powerSaveBlocker.isStarted(id));
        powerSaveBlocker.stop(id)
        Its the correct place ?
        Sorry but im totally new on node.
        Thanks in advance
        S 1 Reply Last reply Mar 14, 2019, 8:01 PM Reply Quote 0
        • S Away
          sdetweil @0v3rNuLL
          complete node helper
          	start: function () {
          		this.started = false;
          		this.isMonitorOn(function(result) {
          			console.log("MMM-MotionDetector: monitor on " + result);
          	activateMonitor: function () {
          			if (!result) {
          				let id = powerSaveBlocker.start('prevent-app-suspension');
          				if(powerSaveBlocker.isStarted(id))
          				exec("vcgencmd display_power 1", function(err, out, code) {
          					if (err) {
          						console.error("MMM-MotionDetector: error activating monitor: " + code);
          					} else {
          						console.log("MMM-MotionDetector: monitor has been activated");
          	deactivateMonitor: function () {
          			if (result) {
          					if (err) {
          					} else {
          	isMonitorOn: function(resultCallback) {
          		exec("vcgencmd display_power", function(err, out, code) {
          			if (err) {
          				console.error("MMM-MotionDetector: error calling monitor status: " + code);
          				return;
          			console.log("MMM-MotionDetector: monitor " + out);
          			resultCallback(out.includes("=1"));
          	// Subclass socketNotificationReceived received.
          	socketNotificationReceived: function (notification, payload) {
          		if (notification === "MOTION_DETECTED" && this.started === false) {
          			console.log("MMM-MotionDetector: MOTION_DETECTED, score " + payload.score);
          			this.started = true;
          			this.activateMonitor();
          		if (notification === "DEACTIVATE_MONITOR" && this.started === false) {
          			console.log("MMM-MotionDetector: DEACTIVATE_MONITOR");
          			this.deactivateMonitor();
          • 0 Offline
            0v3rNuLL
            Finally figured it out, this module now can put the screen off and on (osx el capitan).
            Here is the modification for node_helpder.js
            var cmd=require('node-cmd'); // install node-cmd (npm install node-cmd) first and add excute command osx style then change exec to cmd.get <-- return the result to analize
            			if (!result) {
            				cmd.get('caffeinate -u -t 1', function(err, out, code) {
            					if (err) {
            					} else {
            			if (result) {
            				cmd.get('pmset displaysleepnow', function(err, out, code) {
            					if (err) {
            					} else {
            		cmd.get('pmset -g powerstate IODisplayWrangler | tail -1 | cut -c29', function(err, out, code) {
            			if (err) {
            				return;
            		resultCallback(out.includes("4")); // <4 is off
            This can be marked as SOLVED :slightly_smiling_face:
            • 0 Offline
              0v3rNuLL @sdetweil
              Icant post the entire code so, link to pastebin :)
              node_helper.js
