    I’m getting two instances of MM running
    7 Posts 2 Posters 2.0k Views 2 Watching
      A Former User @dazza120
      @dazza120
      I think you’d installed 2.7.1 by installer script. In that script, registering MM into pm2 exists. It makes duplicated instance beside your existing.
      I think to remove contents of installers/mm.sh is one solution, but not tested.
      PS
      Ignore above suggestion. I’d misunderstood your question.
        dazza120 @Guest
        @Sean Hi Sean mm is working but i have know idea what version is running as you say it creats two, MagicMirror one isnt working how do i clear that up, I can’t even find installers/mm.sh on the pi lol but as said only the MagicMirror version is not working not mm. What would you suggest? Thanks for the assist
          @dazza120
          After pm2 delete, try pm2 save. It will take a snapshot for current status and keep it on next start.
            dazza120 @Guest
            @Sean is there a way of me knowing what version of MM is running? Only one version is running now according to pm2 list, so thank you, but I want to make sure I’m running the correct version to stop the cron jobs running as the old elctron killed it after a few hours.
              @dazza120
              I think it doesn’t matter unless there are two different installation really. (with different folder name). Is that case?
              If you have only one NEW version of MM on your RPI, both apps (MagicMirror or mm) will point same MM. Your case seems just two app(but same instance) registered.
                dazza120 @Guest
                @Sean Thanks Sean no only one folder, so think we are sorted thank you.
