[Remote-Control] Shutdown, Configure and Update your MagicMirror
@costascontis I am experiencing the same issue you are as well.
solved it ,replace node_helper.js with this one ,fix is by ronanversendaal
@costascontis Thanks that worked I think…it doesn’t prompt a pm2 restart in the terminal window just closes MM browser and reopens?
@Jopyth after update the Magic Mirror to v2.7.0. I lost all icons. Do you have any idea why? Thanks in advance
Same issue here 🤔
@Jopyth - the font awesome package was updated in v2.7 so the direct reference to FA in
remote.html
will need to be updated.It looks like this line
link rel="stylesheet" type="text/css" href="vendor/node_modules/font-awesome/css/font-awesome.min.css"
Should be changed to
link rel="stylesheet" type="text/css" href="vendor/css/font-awesome.css"
But I’m away from my mirror right now so cannot test it.
That changed worked for me. I also had issue of white screen on my phone. After the change above and restarting phone, works fine now.
Hello everyone,
I am a little new to MagicMirror and I am trying to control MMM-RTSPStream or somehow hide the stream with MMM-ModuleToggle and Remote Control module.
I am having problems with requests.I have read every example and tryed many things in postman but with no success. I am trying to post these kind of notifications and I don’t know how to formulate request correctly.
This is how Module toggle notification should be formulated:notification: "MODULE_TOGGLE", payload: {hide: ["MMM-RTSPStream"], show: [], toggle:[]}
Or maybe there is a way to cut the stream directly. This is what MMM-RTSPStream suports:
"stream": { "module": "MMM-RTSPStream", "path": "stream", "actions": { "play": { "notification": "RTSP-PLAY", "prettyName": "Play Stream(s)" }, "stop": { "notification": "RTSP-STOP", "prettyName": "Stop Stream(s)" }, "fullscreen": { "notification": "RTSP-PLAY-FULLSCREEN", "prettyName": "Play Fullscreen" }, "window": { "notification": "RSTP-PLAY-WINDOW", "prettyName": "Play in Window" } } } }
I am very grateful for such great modules and I would be very please if you could give me a hint to how to do it.
Regards -
i all i’m new to this world so bear with me plz,
I have built en set-up my daughters SM ( she’s 7 so made her a Disney “mirror, Mirror on the Wall” kinda thing.
I have set up most of the basic stuff, work in progress is;
motion sensor
voicecontole
and the darn MMM remote control
the last one gives me heaps of trouble, i’ve managed to fix a lot problems by trial and error, using this forum as a guideline.
There is one thing, picto’s and “sliders” to turn on off stuff on my phone, i havent been able to fix.I’ve read and applied all the suggested fixes on the forum.
everything works but i’m unable to see if a module is on or off on my phone.
can anyone point me in the right direction, i’m lost atm… not native english (correct my grammer i dont mind, infact it helps)
thanks in advance
p.s. new to programming so be gentle
