    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 940.9k Views 77 Watching
      robiv8
      Nobody an idea?
      Now the notification does not work anymore! Somehow I have the feeling that this block any other modules.
      You can send but it does not matter! Also no error message.
      • N
        nobita @robiv8
        @Jopyth What Happen? and how to solve it?
          robiv8
          I have the impression that Jopyth does not have time to maintain the module. Last answer here was 9 months ago.
          Too bad, is an excellent module
          • Cr4z33C
            Cr4z33 @Jopyth
            @jopyth I’ve done the Italian translation if you would like to add it. ;)
            https://pastebin.com/g7hKLiad
              Jopyth Moderator
              Hi everyone, these is a new version, lots of credit goes to @shbatm for this. Please give it a try and see if it fixed the various issues. There are also better error messages, which might help us narrow down the problem. Without further ado, this is the changelog:
              [2.0.0] - 2019-02-21
              Huge shoutout to shbatm for his work on this new major version, which brings a new API, custom menus and commands and lots of other stuff:
              Added
              • REST API interface for controlling all aspects of the MagicMirror from HTTP RESTful-style GET and POST calls, based on principles from MMM-Api
                • Full API Documentation at API/README.md
              • Live daily updates of modules.json from the MagicMirror wiki, based on principles from MMM-Remote-Control-Repository.
              • Incorporated some features found in MMM-OnScreenMenu that were not originally in this module.
                • Monitor (Connected Screen) On-Off Status and Toggle
                • Delayed calls (“DELAYED” Query option and .../delay API paths)
                • If using Electron: Open Dev Tools, Minimize, Toggle Fullscreen
              • Configuration Option to send custom shell commands to use. Currently, only custom monitor on/off/status commands are supported.
              • Module Control menu - Automatically generated from the API to control the different modules you have installed, based on their notificationReceived function.
              • Custom menu items. See Custom Menu Items in README
              • Norsk bokmål translation
              Changed
              • Updates to remote.html and the node_helper.js to use direct SocketIO communication back and forth instead of separate HTTP calls.
                • Future framework for following PM2 logs and more live update options.
              • General clean-up and standardization of status reporting for GET and POST calls, to original URLs and to new API URLs.
              • Updated to ES2015 (ES Version 6) function calls in most locations.
              • Added USER_PRESENCE controls from AgP42
              • Added/updated french translations from BKeyport and Mysh3ll
              • Added SHOW/HIDE/TOGGLE ALL modules option per request from Rene1709
              Upcoming Changes
              • Add additional MMM-OnScreenMenu features:
                • Moving modules’ positions
              • PM2 Log Follower / Terminal Window
              • Added Notification Echo option to config to echo all Module Notifications to the remote’s DevTools console for debugging.
              • Allow for text input in the Module Controls menu to be able to provide a notification payload.
              Cr4z33C N B 3 Replies Last reply Reply Quote 0
                planet4
                Thanks for doing all the work. Just upgraded. However I had problems before waking and sleeping the screen and before I was able to change this in the node_helper.js to use:
                vcgencmd display_power 1 instead of tvservice. The command works via ssh but when I tried to change like below the screens sleeps but I can not wake it up via the remote.html menu. Anyone with the same problem?
                 monitorControl: function(action, opts, res) {
                            let status = "unknown";
                            let monitorOnCommand = (this.initialized && "monitorOnCommand" in this.thisConfig.customCommand) ?
                                this.thisConfig.customCommand.monitorOnCommand :
                                "sudo vcgencmd display_power 1";
                            let monitorOffCommand = (this.initialized && "monitorOffCommand" in this.thisConfig.customCommand) ?
                                this.thisConfig.customCommand.monitorOffCommand :
                                "vcgencmd display_power 0";
                            let monitorStatusCommand = (this.initialized && "monitorStatusCommand" in this.thisConfig.customCommand) ?
                                this.thisConfig.customCommand.monitorStatusCommand :
                                "vcgencmd display_power --status";
                            if (["MONITORTOGGLE", "MONITORSTATUS", "MONITORON"].indexOf(action) !== -1) {
                                screenStatus = exec(monitorStatusCommand, opts, (error, stdout, stderr) => {
                • Cr4z33C
                  Cr4z33 @Jopyth
                  @jopyth I would love to give it a try, but I need first to replace the monitor on/off commands with more suitable CEC commands (I use the cec-utils package) as I have a TV instead. :)
                  Please tell me what do I have to edit to use the following commands?
                  Turn tv on: echo on 0 | cec-client -s -d 1
                  Turn tv off: echo standby 0 | cec-client -s -d 1
                  Tv status: echo pow 0 | cec-client -s -d 1
                  • N
                    nobita @Jopyth
                    @jopyth ,After git pull and npm install , Error like this (at below) happen
                    what wrong and how to fix it
                    Thanks for your help
                      motdog
                        costascontis
                        @Jopyth nice module but i have an issue ,i think last update broke the restart function.Now its just stops MagicMirror and not restart it.Is there a fix for that?
                        • swvalentiS
                          swvalenti Project Sponsor
                          @costascontis I am experiencing the same issue you are as well.
                            costascontis
                            solved it ,replace node_helper.js with this one ,fix is by ronanversendaal
                            • swvalentiS
                              @costascontis Thanks that worked I think…it doesn’t prompt a pm2 restart in the terminal window just closes MM browser and reopens?
                                bryan_1 @Jopyth
                                @Jopyth after update the Magic Mirror to v2.7.0. I lost all icons. Do you have any idea why? Thanks in advance
                                • htilburgsH
                                  htilburgs
                                  Same issue here 🤔
                                  (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                                  • I
                                    ianperrin
                                    @Jopyth - the font awesome package was updated in v2.7 so the direct reference to FA in remote.html will need to be updated.
                                    It looks like this line
                                    link rel="stylesheet" type="text/css" href="vendor/node_modules/font-awesome/css/font-awesome.min.css"
                                    Should be changed to
                                    link rel="stylesheet" type="text/css" href="vendor/css/font-awesome.css"
                                    But I’m away from my mirror right now so cannot test it.
                                    “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                                      rts58
                                      That changed worked for me. I also had issue of white screen on my phone. After the change above and restarting phone, works fine now.
                                        Duh3c
                                        Hello everyone,
                                        I am a little new to MagicMirror and I am trying to control MMM-RTSPStream or somehow hide the stream with MMM-ModuleToggle and Remote Control module.
                                        I am having problems with requests.
                                        I have read every example and tryed many things in postman but with no success. I am trying to post these kind of notifications and I don’t know how to formulate request correctly.
                                        This is how Module toggle notification should be formulated:
                                        notification: "MODULE_TOGGLE",
                                        payload: {hide: ["MMM-RTSPStream"], show: [], toggle:[]}
                                        Or maybe there is a way to cut the stream directly. This is what MMM-RTSPStream suports:
                                         "stream": {
                                                "module": "MMM-RTSPStream",
                                                "path": "stream",
                                                "actions": {
                                                    "play": {
                                                        "notification": "RTSP-PLAY",
                                                        "prettyName": "Play Stream(s)"
                                                    "stop": {
                                                        "notification": "RTSP-STOP",
                                                        "prettyName": "Stop Stream(s)"
                                                    "fullscreen": {
                                                        "notification": "RTSP-PLAY-FULLSCREEN",
                                                        "prettyName": "Play Fullscreen"
                                                    "window": {
                                                        "notification": "RSTP-PLAY-WINDOW",
                                                        "prettyName": "Play in Window"
                                        I am very grateful for such great modules and I would be very please if you could give me a hint to how to do it.
                                        Regards
                                        • A
                                          apster
                                          i all i’m new to this world so bear with me plz,
                                          I have built en set-up my daughters SM ( she’s 7 so made her a Disney “mirror, Mirror on the Wall” kinda thing.
                                          I have set up most of the basic stuff, work in progress is;
                                          motion sensor
                                          voicecontole
                                          and the darn MMM remote control
                                          the last one gives me heaps of trouble, i’ve managed to fix a lot problems by trial and error, using this forum as a guideline.
                                          There is one thing, picto’s and “sliders” to turn on off stuff on my phone, i havent been able to fix.
                                          I’ve read and applied all the suggested fixes on the forum.
                                          everything works but i’m unable to see if a module is on or off on my phone.
                                          can anyone point me in the right direction, i’m lost atm… not native english (correct my grammer i dont mind, infact it helps)
                                          thanks in advance
                                          p.s. new to programming so be gentlealt text
                                          • StoffbeuteluweS
                                            Stoffbeuteluwe Project Sponsor @apster
                                            @apster - the font awesome package was updated in v2.7 so the direct reference to FA in remote.html will need to be updated.
                                            link rel=“stylesheet” type=“text/css” href=“vendor/node_modules/font-awesome/css/font-awesome.min.css”
                                            link rel=“stylesheet” type=“text/css” href=“vendor/css/font-awesome.css”
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
