    Infinity Magic mirror
    8 Posts 3 Posters 4.9k Views 4 Watching
      A Former User @icripps
      @icripps
      Infinity means this?
      But In that case we need “Transparent LCD” for that effect.
      • I Offline
        icripps
        @Sean yeah , exactly. But transparent lcd? I have never heard of one. Is it like the one above? If my imagination is right then I think it will be awesome.
          @icripps
          The infinity effect comes from infinite reflection between 2 mirrors(one spymirror, one common mirror). See the first image and Imagine to put ugly bearbone LCD panel or frame, instead “K” mark. I can bet that would be not what you want really. (But if you want, who cares.)
          If your intent was “Floating things between infinity reflection”, in that case transparent LCD will be needed.
          • I Offline
            icripps @Guest
            @Sean yeah , I would need a transparent lcd. Hopefully there’s a way to turn the current led monitor am using into a transparent monitor. Is that a good idea ?
              @icripps
              You can tear down normal TFT-LCD and remove backlight, then you can get thin transparent LCD film. The only problem is, without back-Light, you cannot see anything. But Infinite mirror might not be bright due to it’s structure.
              If you can get transparent OLED, it will work with dark background, but so expensive really.
              https://www.youtube.com/watch?v=IpOsTbXLxro
              • I Offline
                icripps
                @Sean thats so expensive. Maybe I will try this again some time in the future. Thanks though.
                • T Offline
                  tirando
                  hey, maybe it’s possible by replacing the common mirror of infinity mirror by two-way mirror and put your monitor behind ? i don’t know but maybe the infinite effect would be less strong .
                  (sorry if my English is not very good i’m french)
