Default calender change Header position
Hey guys,
i’m completly new in this world, but the possibilities are great.
The modul default calendar is set with “top-right”, now the header is also at the right side of the modul.I search the .css and the calendar.js, but i couldn’t find the possibility to set header “margin:left” oder “float:left” wthatever.
is would be very nice, if somebody could help me ;-)
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "MMM-DigClock", position: "top_right", // This can be any of the regions. config: { showDate: true, showWeek: false, showSeconds: false, dateFormat: "ddd, ll", timezone: "Europe/Berlin" } }, { module: "weatherforecast", position: "top_right", header: "WIE WIRD DAS WETTER?", config: { location: "yyyyyyyyy", locationID: "yyyyyyy", //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city appid: "xxxxxxxx" } }, { module: "calendar", header: "Termine xxxxxxxx", position: "top_right", config: { timeFormat: "absolute", maximumEntries: "5", maximumNumberOfDays: "365", getRelative: 48, calendars: [ { symbol: "calendar-check", url: "webcal://xxxxxxxxxxxxx" } ] } }, { module: "MMM-EasyPix", position: "top_left", config: { picName: "vp_2.png", // Enter the picture file name. maxWidth: "33%", // Size picture precisely. Retains aspect ratio. sounds: ["1.mp3", "me2.mp3"], // mp3 sound file names in quotes seperated by commas for Hello-Lucy updateInterval: 30 * 60 * 1000, // updates display animationSpeed: 3000, } }, { module: "MMM-EasyPix", position: "top_center", config: { picName: "vp_2.png", // Enter the picture file name. maxWidth: "66%", // Size picture precisely. Retains aspect ratio. sounds: ["1.mp3", "me2.mp3"], // mp3 sound file names in quotes seperated by commas for Hello-Lucy updateInterval: 30 * 60 * 1000, // updates display animationSpeed: 3000, } }, { module: "MMM-EARTH", position: "bottom_right", config: { mode: "Natural", rotateInterval: 15000, MaxWidth: "35%", MaxHeight: "35%", } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Tagesschau", url: "http://www.tagesschau.de/xml/rss2" }, { title: "Der Spiegel", url: "http://www.spiegel.de/schlagzeilen/tops/index.rss" }, ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
Try
div.module.calendar header { }if that doesnt work, give me a few hours to get home and actually look at my custom.css file
where should i write this code?
custom.css??actually she look like this (with your Command):
body { } div.module.calendar header { } -
ill get you the full code in a few hours…yes in custome css but you will also need to alight the text properly too.
sorry here was s the css code
.calendar header { text-align: center // Change this to whatever you want....right,center or left } -
Thank you!
i’ll try and give you feedback!
