    MM remote access works, but no display on host machine
    3 Posts 1 Posters 969 Views 1 Watching
      I am helping a user debug their system
      i can start MM without problems, but… the ui doesn’t not come up
      i can access the mirror from my other system thru a browser at its ip address and port just fine…
      another instance on MM (my production version) is happy and shows the UI and can be accessed remote as well…
      any ideas how to debug?
        @sdetweil Ok, copied the node_modules/electron folder tree from the good working install to replace the bad… and now the bad behaves…
          @sdetweil running node_modules/electron/dist/electron http://cnn.com produces a frame on the host, but there is no content
          so, this appears to be an electron problem
