    MMM-PIR doesn´t turn off monitor since update MM 2.7
    25 Posts 9 Posters 12.3k Views 9 Watching
      shgmongohh @sdetweil
      Thanks for your help, but i get the follwing errer, wenn i type in
      pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $  ./node_modules/.bin/electron-rebuild
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      gyp info it worked if it ends with ok
      gyp info using node-gyp@3.8.0
      gyp info using node@10.15.3 | linux | arm
      gyp http GET https://atom.io/download/electron/v3.0.13/iojs-v3.0.13-headers.tar.gz
      gyp http 200 https://atom.io/download/electron/v3.0.13/iojs-v3.0.13-headers.tar.gz
      gyp http GET https://atom.io/download/electron/v3.0.13/SHASUMS256.txt
      gyp http 200 https://atom.io/download/electron/v3.0.13/SHASUMS256.txt
      gyp info spawn /usr/bin/python2
      gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/gyp/gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'make',
      gyp info spawn args   '-I',
      gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/build/config.gypi',
      gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/addon.gypi',
      gyp info spawn args   '/root/.electron-gyp/iojs-3.0.13/common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=/root/.electron-gyp/iojs-3.0.13',
      gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp',
      gyp info spawn args   '-Dnode_lib_file=/root/.electron-gyp/iojs-3.0.13/<(target_arch)/iojs.lib',
      gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'build',
      gyp info spawn args   '-Goutput_dir=.' ]
      gyp info spawn make
      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/build'
        CXX(target) Release/obj.target/wiringPi/src/addon.o
        CXX(target) Release/obj.target/wiringPi/src/wiringPi.o
      ../src/wiringPi.cc: In function 'void nodemodule::setup(const v8::FunctionCallbackInfo<v8::Value>&)':
      ../src/wiringPi.cc:52:53: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated (declared at /root/.electron-gyp/iojs-3.0.13/deps/v8/include/v8.h:2819): Use Isolate version [-Wdeprecated-declarations]
           String::Utf8Value mode(GET_ARGUMENT_AS_STRING(0));
      In file included from ../src/wiringPi.h:4:0,
                       from ../src/wiringPi.cc:1:
      ../src/wiringPi.cc: In function 'void nodemodule::initwiringPi(v8::Isolate*, v8::Handle<v8::Object>)':
      ../src/addon.h:45:15: error: 'class v8::Object' has no member named 'ForceSet'
             target->ForceSet(v8::String::NewFromUtf8(isolate, #name, v8::String::kInternalizedString), \
      ../src/wiringPi.cc:714:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(WPI_MODE_PINS);
      ../src/wiringPi.cc:715:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(WPI_MODE_PHYS);
      ../src/wiringPi.cc:716:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(WPI_MODE_GPIO);
      ../src/wiringPi.cc:717:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(WPI_MODE_GPIO_SYS);
      ../src/wiringPi.cc:718:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(WPI_MODE_PIFACE);
      ../src/wiringPi.cc:719:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(WPI_MODE_UNINITIALISED);
      ../src/wiringPi.cc:723:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(INPUT);
      ../src/wiringPi.cc:724:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(OUTPUT);
      ../src/wiringPi.cc:725:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PWM_OUTPUT);
      ../src/wiringPi.cc:726:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(GPIO_CLOCK);
      ../src/wiringPi.cc:727:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(SOFT_PWM_OUTPUT);
      ../src/wiringPi.cc:728:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(SOFT_TONE_OUTPUT);
      ../src/wiringPi.cc:731:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PUD_OFF);
      ../src/wiringPi.cc:732:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PUD_DOWN);
      ../src/wiringPi.cc:733:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PUD_UP);
      ../src/wiringPi.cc:736:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(HIGH);
      ../src/wiringPi.cc:737:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(LOW);
      ../src/wiringPi.cc:740:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PWM_MODE_BAL);
      ../src/wiringPi.cc:741:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PWM_MODE_MS);
      ../src/wiringPi.cc:744:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_UNKNOWN);
      ../src/wiringPi.cc:745:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_A);
      ../src/wiringPi.cc:746:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_B);
      ../src/wiringPi.cc:747:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_BP);
      ../src/wiringPi.cc:748:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_CM);
      ../src/wiringPi.cc:749:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_AP);
      ../src/wiringPi.cc:750:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MODEL_2);
      ../src/wiringPi.cc:752:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_VERSION_UNKNOWN);
      ../src/wiringPi.cc:753:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_VERSION_1);
      ../src/wiringPi.cc:754:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_VERSION_1_1);
      ../src/wiringPi.cc:755:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_VERSION_1_2);
      ../src/wiringPi.cc:756:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_VERSION_2);
      ../src/wiringPi.cc:758:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MAKER_UNKNOWN);
      ../src/wiringPi.cc:759:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MAKER_EGOMAN);
      ../src/wiringPi.cc:760:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MAKER_SONY);
      ../src/wiringPi.cc:761:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MAKER_QISDA);
      ../src/wiringPi.cc:762:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(PI_MAKER_MBEST);
      ../src/addon.h:68:17: error: 'class v8::Object' has no member named 'ForceSet'
      ../src/wiringPi.cc:764:3: note: in expansion of macro 'EXPORT_CONSTANT_STRING_ARRAY'
         EXPORT_CONSTANT_STRING_ARRAY(PI_MODEL_NAMES, piModelNames, 7);
      ../src/wiringPi.cc:765:3: note: in expansion of macro 'EXPORT_CONSTANT_STRING_ARRAY'
         EXPORT_CONSTANT_STRING_ARRAY(PI_REVISION_NAMES, piRevisionNames, 5);
      ../src/wiringPi.cc:766:3: note: in expansion of macro 'EXPORT_CONSTANT_STRING_ARRAY'
         EXPORT_CONSTANT_STRING_ARRAY(PI_MAKER_NAMES, piMakerNames, 5);
      ../src/wiringPi.cc:769:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_INPT);
      ../src/wiringPi.cc:770:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_OUTP);
      ../src/wiringPi.cc:771:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_ALT0);
      ../src/wiringPi.cc:772:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_ALT1);
      ../src/wiringPi.cc:773:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_ALT2);
      ../src/wiringPi.cc:774:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_ALT3);
      ../src/wiringPi.cc:775:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_ALT4);
      ../src/wiringPi.cc:776:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
         EXPORT_CONSTANT_INT(FSEL_ALT5);
      wiringPi.target.mk:142: recipe for target 'Release/obj.target/wiringPi/src/wiringPi.o' failed
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/build'
      make: *** [Release/obj.target/wiringPi/src/wiringPi.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.9.35-v7+
      gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=3.0.13" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi
      gyp ERR! node -v v10.15.3
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      Failed with exit code: 1
      Error: gyp info it worked if it ends with ok
      gyp info spawn make
      thedoorsfanaticT T 2 Replies Last reply Reply Quote 0
        well, ain’t that a doozy…
        not sure…
        • thedoorsfanaticT Offline
          thedoorsfanatic @shgmongohh
          @shgmongohh
          I use MMM-PIR-Sensor and it works just fine on 2.7.1
          https://github.com/paviro/MMM-PIR-Sensor
          My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
            shgmongohh @thedoorsfanatic
            @thedoorsfanatic
            Thanks for the information. I uninstall and install MMM-PIR, but it doesn´t work.
            Regards,
            Sebastian
            • F Offline
              Fonfon
              same problem with MMM-PIR-sensor and 2.7.1
              i do that :
              from the MMM-PIR-Sensor folder
              npm install electron-rebuild
              then run it to force the epoll rebuild
                shgmongohh @Fonfon
                @Fonfon
                How do you force the epoll rebuild?
                • F Offline
                  Fonfon
                  @sdetweil said in MMM-PIR doesn´t turn off monitor since update MM 2.7:
                  @sdetweil give the solution
                    sdetweil @Fonfon
                    @Fonfon did give the solution?
                    • F Offline
                      Fonfon @sdetweil
                      i believe that you will have to force recompile in the MMM-PIR folder… as the dependent epoll module doesn’t supply a version for this version of electron
                      from MMM-PIR folder do
                      then
                      i do that but not in my MMM-PIR folder but in my MMM-PIR-Sensor folder
                        sdetweil @Fonfon
                        @Fonfon and all is good?
