    api info to table
    6 Posts 2 Posters 2.7k Views 2 Watching
    • E Offline
      epi
      Can someone make a simple mm module?
      Get data from any of those api https://github.com/opendata-stuttgart/meta/wiki/APIs and make a table out of them?
      Only 4 parameters needs to be fetched & displayed: PM2.5, PM10, temperature, humidity
        sdetweil @epi
        @epi see https://github.com/timdows/MMM-JsonTable
        • E Offline
          epi
          can I ask for help?
          i did install everything, but i’m seeing errors for “json data is not of type array”
          can you help me with exact url (https://docs.opensensemap.org/)?
            sdetweil @epi
            @epi in the original link, the apis listed below “Accessing the API data:” show returning an array of values
            • E Offline
              epi
              @sdetweil still get the same error. here is the url
              https://api.opensensemap.org/boxes/57000b8745fd40c8196ad04c
              • E Offline
                epi @epi
                ok, found the issue, needed to define arrayName. Thanks!
