MMM-google-route and coordinates
7 Posts 2 Posters 1.7k Views 2 Watching
  • Z Offline
    Zippyczech
    Hey guys,
    I´m working on my MM, and I found module MMM-google-route which I want to use for showing the route from my home to my work, but I´m not able to set the coordinates from google.maps.DirectionsRequest interface because of my lack of skills :) Any help would be welcomed.
    Btw, for anyone who want to use the module, there is mistake on github example, its missing , at end of the exaple, its should be
                module: 'MMM-google-route',
                position: 'top_left',
                    key: '<YOUR_KEY>',
                    directionsRequest:{
                        origin: '<ROUTE START>',
                        destination: '<ROUTE FINISH>'
    code_text
    S 1 Reply Last reply May 26, 2019, 11:42 AM Reply Quote 0
      sdetweil @Zippyczech
      @Zippyczech use the latitude/longitude…
      open google maps, find the location
      in the address bar/location
      for New York, Ny, USA
      maps/place/New+York,+NY/@40.6971478,-74.2605536,
      the 2 numbers are the latitude (above/below equator), and longitude (east/west of London, approx)
      use one set for origin and one for destination
      • Z Offline
        Zippyczech
        I´m retarded, of course, it worked. I tried the first time and did some mistake so it didnt work.
        Thank you
        Btw, do you know how to specify that the route should use subway only?
        S 1 Reply Last reply May 27, 2019, 12:48 PM Reply Quote 0
          @Zippyczech sorry. Don’t know anything about the module
            Looking at the code, it appears u could change the code to support train
            travelMode: 'DRIVING'
            But not thru config altho that would be an easy change I think.
            • Z Offline
              Zippyczech
              Thank you, again, solved it moments later :) I used https://github.com/jclarke0000/MMM-MyCommute which has better configuration options
              S 1 Reply Last reply May 27, 2019, 4:05 PM Reply Quote 1
                @Zippyczech cool. Thanks for providing feedback.
