    MM ClientOnly + Docker as a server on the same machine
    2 Posts 2 Posters 1.0k Views 2 Watching
    • SergeS
      Serge
      Hallo,
      I need to run MagicMirror as a server and client at the same raspberry.
      For this purposes I have:
      1. installed MM server docker container (as per https://github.com/bastilimbach/docker-MagicMirror) . It works fine and accessible through browser at 172.17.0.1 and at localhost.
      2. installed MM and through automatic installation
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      1. run MM client according to the manual:
      npm start && node clientonly --address 172.17.0.1 --port 8080
      Here is the log
      pi@raspberrypi:~/MagicMirror $ npm start && node clientonly --address 172.17.0.1 --port 8080
      > magicmirror@2.7.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.7.1
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Starting module: newsfeed
      { Error: listen EADDRINUSE 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (net.js:1330:14)
          at listenInCluster (net.js:1378:12)
          at doListen (net.js:1492:7)
          at process._tickCallback (internal/process/next_tick.js:63:19)
          at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
          at startup (internal/bootstrap/node.js:241:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
        errno: 'EADDRINUSE',
        code: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080 }
      Launching application.
      ^CShutting down server...
      config.js is configured as the following:
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      Could anyone tell me what should i look at?
      I need to run both (1) MM server in a docker container and (2) MM client at the same Raspberry.
        sdetweil @Serge
        @Serge npm start, starts the full system, and node clientonly starts the client
        But u have a server already using docker so, only do node clientonly
