    Fresh install, Cannot find module 'depd'
    11 Posts 2 Posters 4.6k Views 2 Watching
      alborzs
      I had an old installation of mm, while pulling the latest code, I managed to mess things up so I removed everything and reinstalled mm.
      Now I am getting the following error:
      pi@raspberrypi:~/MagicMirror $ pm2 logs 1
      [TAILING] Tailing last 15 lines for [1] process (change the value with --lines option)
      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
      1|MagicMir | > magicmirror@2.8.0 start /home/pi/MagicMirror
      1|MagicMir | > sh run-start.sh
      1|MagicMir |
      1|MagicMir |
      1|MagicMir |
      1|MagicMir |
      1|MagicMir |
      1|MagicMir |
      1|MagicMir |
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      1|MagicMir | Error: Cannot find module 'depd'
      1|MagicMir |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      1|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      1|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      1|MagicMir |     at Module.require (internal/modules/cjs/loader.js:658:17)
      1|MagicMir |     at require (internal/modules/cjs/helpers.js:20:18)
      1|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/body-parser/index.js:14:17)
      1|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/body-parser/index.js:159:3)
      1|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:711:30)
      1|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
      1|MagicMir |     at Module.load (internal/modules/cjs/loader.js:620:32)
      1|MagicMir | libGL error: MESA-LOADER: failed to retrieve device information
      1|MagicMir | MESA-LOADER: failed to retrieve device information
      1|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
      Any idea what I am doing wrong, I have not even added any modules yet! It is just the fresh install.
        sdetweil @alborzs
        @alborzs said in Fresh install, Cannot find module 'depd':
        Cannot find module ‘depd’
        how did u install?
          alborzs
          @sdetweil , I just used the install script.
          bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
            sdetweil @alborzs
            @alborzs I don’t see any code requiring depd…
            can u tell me you node and npm versions
            node -v
            npm -v
              alborzs
              Please see below:
              pi@raspberrypi:~ $ node -v
              v9.11.2
              pi@raspberrypi:~ $ npm -v
              5.6.0
                sdetweil @alborzs
                @alborzs do
                npm i -g npm
                looks downlevel… I am at 6.9.0
                  alborzs
                  @sdetweil,
                  I tried that as sudo, still getting the exact same issue:
                  pi@raspberrypi:~ $ sudo npm i -g npm
                  /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                  /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                  + npm@6.10.0
                  added 323 packages, removed 364 packages and updated 55 packages in 275.817s
                  pi@raspberrypi:~ $ cd MagicMirror/
                  pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: 1)
                  [PM2] [MagicMirror](1)
                   Use `pm2 show <id|name>` to get more details about an app
                  pi@raspberrypi:~/MagicMirror $ pm2 logs MagicMirror
                  [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                  1|MagicMir |
                  1|MagicMir |
                  1|MagicMir |
                  1|MagicMir |
                  1|MagicMir |
                  1|MagicMir |
                  1|MagicMir |
                    sdetweil @alborzs
                    @alborzs ok, you ran ahead
                    now go to MagicMirror folder and do
                    npm install
                    again
                      alborzs
                      @sdetweil ,
                      I tried that, below is the result, still getting the same result.
                      pi@raspberrypi:~/MagicMirror $ npm install
                      > magicmirror@2.8.0 install /home/pi/MagicMirror
                      > cd vendor && npm install
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      audited 220 packages in 9.1s
                      found 5 vulnerabilities (4 low, 1 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                      > sh installers/postinstall/postinstall.sh && npm run install-fonts
                      MagicMirror installation successful!
                      > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                      > cd fonts && npm install
                      audited 1 package in 1.117s
                      found 0 vulnerabilities
                      audited 3558 packages in 56.93s
                        alborzs
                        1|MagicMir | A JavaScript error occurred in the main process
                        1|MagicMir | Uncaught Exception:
                          sdetweil @alborzs
                          @alborzs weird…
