    Error with dependencies, but it's different then the other ones just posted?!?!?
    11 Posts 3 Posters 3.6k Views 4 Watching
      stalker401 @tcsabina
      @tcsabina awesome thanks. Ill get on that after work today
        stalker401
        So I ran from the MagicMirror directory and not from it:
        pi@raspberrypi:~ $ npm -v
        1.4.21
        (node:1633) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        pi@raspberrypi:~ $ node -v
        v8.11.1
        pi@raspberrypi:~ $ cd MagicMirror
        pi@raspberrypi:~/MagicMirror $ npm -v
        1.4.21
        (node:1641) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        pi@raspberrypi:~/MagicMirror $ node -v
        v8.11.1
        I hope this helps. If I screwed up somehow let me know.
          sdetweil @stalker401
          @stalker401 npm is WAY downlevel
          Do
          npm i -g npm
          Then redo the npm -v
          Should be 6.?.?
            stalker401
            I ran it, and I have a feeling I screw up:
            Not from MagicMirror:
            pi@raspberrypi:~ $ npm i -g npm
            (node:2262) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            npm ERR! tar.unpack untar error /home/pi/.npm/npm/6.10.1/package.tgz
            npm ERR! Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/npm'
            npm ERR!  { Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/npm'
            npm ERR!   errno: -13,
            npm ERR!   code: 'EACCES',
            npm ERR!   syscall: 'mkdir',
            npm ERR!   path: '/usr/local/lib/node_modules/npm',
            npm ERR!   fstream_type: 'Directory',
            npm ERR!   fstream_path: '/usr/local/lib/node_modules/npm',
            npm ERR!   fstream_class: 'DirWriter',
            npm ERR!   fstream_stack:
            npm ERR!    [ '/usr/lib/nodejs/fstream/lib/dir-writer.js:35:25',
            npm ERR!      '/usr/lib/nodejs/mkdirp/index.js:46:53',
            npm ERR!      'FSReqWrap.oncomplete (fs.js:152:21)' ] }
            npm ERR!
            npm ERR! Please try running this command again as root/Administrator.
            npm ERR! System Linux 4.19.57-v7+
            npm ERR! command "/usr/bin/node" "/usr/bin/npm" "i" "-g" "npm"
            npm ERR! cwd /home/pi
            npm ERR! node -v v8.11.1
            npm ERR! npm -v 1.4.21
            npm ERR! path /usr/local/lib/node_modules/npm
            npm ERR! syscall mkdir
            npm ERR! fstream_path /usr/local/lib/node_modules/npm
            npm ERR! fstream_type Directory
            npm ERR! fstream_class DirWriter
            npm ERR! code EACCES
            npm ERR! errno -13
            npm ERR! stack Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/npm'
            npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/dir-writer.js:35:25
            npm ERR! fstream_stack /usr/lib/nodejs/mkdirp/index.js:46:53
            npm ERR! fstream_stack FSReqWrap.oncomplete (fs.js:152:21)
            npm ERR! Error: EACCES: permission denied, open 'npm-debug.log'
            npm ERR!  { Error: EACCES: permission denied, open 'npm-debug.log'
            npm ERR!   syscall: 'open',
            npm ERR!   path: 'npm-debug.log' }
            npm ERR!
            npm ERR! path npm-debug.log
            npm ERR! syscall open
            npm ERR! errno -13
            npm ERR! stack Error: EACCES: permission denied, open 'npm-debug.log'
            npm ERR!
            npm ERR! Additional logging details can be found in:
            npm ERR!     /home/pi/npm-debug.log
            npm ERR! not ok code 0
            1.4.21
            (node:2273) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            and than from MagicMirror:
            pi@raspberrypi:~/MagicMirror $ npm i -g npm
            (node:2633) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            npm ERR!
            npm ERR! cwd /home/pi/MagicMirror
            npm ERR! errno -13
            npm ERR!
            npm ERR!     /home/pi/MagicMirror/npm-debug.log
            1.4.21
            (node:2688) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
              stalker401
              Ok figured out I’m an idiot:
              pi@raspberrypi:~/MagicMirror $ sudo npm i -g npm
              (node:2766) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
              npm WARN package.json path-is-inside@1.0.2 No README data
              npm WARN package.json sorted-object@2.0.1 No README data
              npm WARN package.json config-chain@1.1.12 No license field.
              npm WARN package.json cyclist@0.2.2 No license field.
              npm WARN package.json json-schema@0.2.3 No license field.
              npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
              npm WARN package.json qrcode-terminal@0.12.0 No license field.
              npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
              /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
              /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
              npm@6.10.1 /usr/local/lib/node_modules/npm
              pi@raspberrypi:~/MagicMirror $ sudo npm -v
              6.10.1
              I’m guessing I need to run this not from MagicMirror and rerun the bash for MagicMirror again?
                stalker401
                Ok so here’s what I got:
                pi@raspberrypi:~ $ sudo npm i -g npm
                /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                + npm@6.10.1
                added 433 packages from 823 contributors in 44.875s
                pi@raspberrypi:~ $ sudo npm -v
                6.10.1
                Do I just need to change the name of hte MagicMirror folder and rerun the bash again?
                  @stalker401 sorry, I should have mentioned u might need sudo.
                  But you got it!
                  Rename and rerun bash is the easiest
