    MMM-AssistantMk2
    421 Posts 61 Posters 803.9k Views 57 Watching
    • saljokeS
      saljoke
      Wonderful. I want to try these changes!!!
        smarthome
        Hello
        How can I stop Assistant’s response and make request again like Google Home Speaker can ?
          smarthome @smarthome
          This is my config, still don’t work yet
              module: "MMM-AssistantMk2",
                notifications: {
                  ASSISTANT_UNDERSTOOD: "HOTWORD_RESUME",
            module: "MMM-Hotword",
              models: [
                  hotwords    : "stop",
                  file        : "stop.pmdl",
                  sensitivity : "0.5",
              command: {
                "stop":{
                notificationExec: {
                  notification: "ASSISTANT_CLEAR",
                  payload: (detected, afterRecord) => {
                    return {profile:"default"}
                afterRecordLimit:0,
                restart:false,
          ? 1 Reply Last reply
            A Former User @smarthome
            @smarthome Sorry, at this moment, there is no way to interrupt response. Just wait ends.
              smarthome @Guest
              @Sean said in MMM-AssistantMk2:
              Tks for your quick answer! Can we make a command exec to mpg21 to stop blayback google response?
              S ? 2 Replies Last reply
                And other question is, if I ask a command that Google can not find the suitable answer, there’s no response while google home speaker give a promise answer? Is there any configure to do that?
                  @smarthome
                  Ideally, might be possible. But not only playing sound is the issue related. So, currently not so easy.
                  Currently, No.
                  Anyway, I’m building a new updates. It might have possibility of solving your issue. I’m planning to remove dependencies about sound out. It might become more controllable about voice response.
                  But due to my vacation, and new RPI4, Raspiban Buster and other many things which I should concern besides make its release somewhat lately. sorry.
                  S 2 Replies Last reply
                    smarthome @Guest
                      smarthome @Guest
                      @Sean
                      How can I remove “Repeat after me” whenever ask ASSISTANT _SAY to speech text?
                        @smarthome Impossible. ASSISTANT_SAY is not perfect solution to make mirror saying something. At any time it could be changed by Google how it works. When I implement that feature at first time, there is no additional “Repeat after me” spoken phrase, but Google changed it’s working way. So I didn’t recommend using it. Use real TTS solution to make your mirror say something.
                          smarthome @Guest
                          @Sean
                          I’ also active billing account to enable Google Cloud text to Speech API to use your MMM Google-TTS Module
                          But, this can not speak my local language (Vietnamese) like ASSISTANT_SAY can
                          How to do that?
                            @smarthome
                            Sorry, Vietnamese is not supported (https://cloud.google.com/text-to-speech/docs/voices)
                              smarthome @Guest
                              @Sean
                              After your answer, I’m looking for google cloud amd find out the way to make it support, hi
                              Not only Vietnamese language, a wide range of local language, like assistant language
                              That’ now MMM Google TTS work ok with vietnamese language
                              Tks!
                              • T
                                t.architecture99
                                How can google TTS respond to the answers I have prepared? eg :
                                • “smart mirror, I want to drink something.” - Me
                                • “This is your drink.” - Smart mirror answers.
                                  So how to do that?
                                  I have successfully installed the api and modules, but i dont know how…
                                  Sorry i am newbie
                                  A Former User @t.architecture99
                                  @t-architecture99
                                  Recommending beverage is not the job of this module.
                                  But if you have MMM-RecommendDrinks (Of course, currently it exists not), You can make an order of I want to drink something to MMM-AssistantMk2 then, AMK2 would transfer your order to that RD module, and RD can RESPONSE with voice via TTS module.
                                  So, that feature is for developers not for end-users directly.
                                  T 1 Reply Last reply
                                  • T
                                    t.architecture99 @Guest
                                    @Sean i mean i want to set default question and answers with voice response (using google TTS. I dont know how to command to create . :(
                                      @t-architecture99
                                      By default, If the response could be handled by Assistant itself, it can response with voice. (e.g : “How’s the weather today?” - “It’s rainy blah blah…”)
                                      So what is your default question? hmmm… It’s better to tell me “YOUR REAL INTENTION or SCENARIO” - what you want.
                                      In case that you need some extended response from MM & modules
                                      By example,
                                      • if you want to get a response “Yes, sir!” when you order “Shut down now” (by your custom command),
                                        • Use custom action instead transcriptionHook on making a command. custom action can handle a simple static voice response.(around 150 words)
                                      • But more complex dynamic conversation like - “Read me first article of news module” then “New york times said blah blah…”
                                        • You should modify news module to speak somethings, and at that time TTS solution be needed.
                                        • And the role of AMK2 is just sending “Read first article” order to news module. That is the way how it works.
                                      • E
                                        EstoyMejor
                                        Hello guys, i hope someone can help me here. I found several people with the same problem but all got fixed by the Troubleshooting in the README, mine doesnt (or maybe i did something wrong?!)
                                        My problem is this error:
                                        Error: Failed to load gRPC binary module because it was not installed for the current system
                                        Expected directory: electron-v3.1-linux-arm-glibc
                                        Found: [node-v72-linux-arm-glibc]
                                        Full start sequence log:
                                        pi@InfoDisplayPi:~/MagicMirror $ npm start
                                        > magicmirror@2.8.0 start /home/pi/MagicMirror
                                        > sh run-start.sh
                                        Starting MagicMirror: v2.8.0
                                        Loading config ...
                                        Loading module helpers ...
                                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                        This problem can often be fixed by running "npm rebuild" on the current system
                                        Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.1-linux-arm-glibc/grpc_node.node'
                                        App threw an error during load
                                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
                                            at Module._compile (internal/modules/cjs/loader.js:711:30)
                                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                            at Module.load (internal/modules/cjs/loader.js:620:32)
                                            at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                            at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                            at Module.require (internal/modules/cjs/loader.js:658:17)
                                            at require (internal/modules/cjs/helpers.js:20:18)
                                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                                        { Error: Failed to load gRPC binary module because it was not installed for the current system
                                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
                                        Launching application.
                                        Shutting down server...
                                        Stopping module helper: updatenotification
                                        Stopping module helper: calendar
                                        Stopping module helper: newsfeed
                                        I Feel like i just oversee something really easy here…
                                          A Former User @EstoyMejor
                                          @EstoyMejor
                                          Your electron-rebuild was failed on installation.
                                          If your gcc version is 8, downgrade to 7 and reinstall again.
                                          • W
                                            witty11
                                            hello Guy, i would like to ask you about mmm GAction Register ,i have to do that when i installed MMM assistantmk2 does i need to do it again or skip to step scp ~/Downloads/client_secret_client-id.json pi@raspberry-pi-ip-address:/home/pi/
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 21
                                            • 22
                                            • 16 / 22
