    MMM-Spotify
    249 Posts 51 Posters 365.1k Views 54 Watching
      A Former User @Ivanov_d
      @Ivanov_d
      Only that command doesn’t work? Other’s OK?
      Raspotify should be already running when you use this module. (This module cannot boot up Raspotify itself)
      • I
        Ivanov_d
        @Sean yes, the other commands work. I can skip the song, increase/decrease the volume and etc. Also Raspotify is running, because I can start the playback on the mirror from my Desktop/Smartphone app.0_1563467613897_Untitled20190718193321.png
        • I
          Ivanov_d
          @Sean, I did some more testing and I can confirm that this is the only command that doesn’t work. Maybe I am not understanding it correctly.
          My expected results would be:
          1. Raspotify is running in the background (but no music is playing)
          2. When I say “music please” spotify will start a random song and play it on the MagicMirror
          The result however is:
          1. Raspotify is running in the background and no music is playing
          2. When I say “music please” I see no errors in the logs, however, no music is starting as well
          3. To workaround this I start the music from my smartphone or desktop app and switch the player to MagicMirror, after that I can control the player via AssistankMK2
          ? 2 Replies Last reply
            @Ivanov_d
            There could be 2(or 3)kinds of possibility about your issue;
            1. AssistantMk2 cannot catch your word “music please”
            2. AssistantMk2 could catch “music please” but cannot emit “SPOTIFY_PLAY” notification
            3. Spotify cannot receive (or understand) SPOTIFY_PLAY notification. (hmmm… I can’t agree about this)
            Well, I’ll test from last third issue. Wait for a while.
              @Ivanov_d
              I just tested 3rd case, and there is no problem to work. I think your music please phrase is not hooked, because music is reserved word for default Music feature of Assistant itself(for Youtube Music or Spotify on Google Home itself, but not yet supported by SDK for devices - only allowed for Google Home or some genuine devices). Some keywords or phrases are reserved for Google itself. Unless you override the keywords by Custom Action for Assistant (And even though, cannot guarantee it will work), your music keyword couldn’t work.
              Can you try other phrase? like “stay tune.” or any phrase you like.
              • I
                Ivanov_d
                @Sean I will try that and report back. Thanks for the suggestion.
                • F
                  Faiek
                  Hi Guys need some help with this module - newbie :smirking_face:
                  I have the following loaded succesfully:
                  AssistantMk2
                  Hotword
                  Raspotify
                  Change device name in Raspotify :to Mirror
                  Created a spotify.json - recipe(code from here) in recipes file this is it:
                  Added the recipe to the Mk2.js
                  recipes:[“hide_and_show_all_modules.js”, “reboot.js”, “screen_onoff.js”, “shutdown.js”, “spotify.js”],
                  Dont know what i missed - any assistance please …
                  var recipe = {
                  transcriptionHook: {
                            STOP_PLAY: {
                              pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                              command: "STOP_VID"
                           // STOP_PLAY2: {
                           //   pattern: "arrête la musique",
                           //   command: "STOP_VID"
                  	 SPOTIFY_PREVIOUS: {
                          pattern: "previous song",
                          command: "SPOTIFY_PREVIOUS"
                          SPOTIFY_PAUSE: {
                          pattern : "stop the musique",
                          command: "SPOTIFY_PAUSE"
                          SPOTIFY_PLAY: {
                          pattern : "music please",
                          command: "SPOTIFY_PLAY"
                          SPOTIFY_NEXT: {
                          pattern: "next song",
                          command: "SPOTIFY_NEXT"
                          SPOTIFY_VOLUME: {
                          pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                          command: "SPOTIFY_VOLUME"
                          SPOTIFY_SEARCH: {
                          pattern: "play (.*) on Spotify",
                          command: "SPOTIFY_SEARCH"
                  	SPOTIFY_SEARCH_PLAYLIST: {
                          pattern: "playlist (.*) on Spotify",
                          command: "SPOTIFY_SEARCH_PLAYLIST"
                  	SPOTIFY_MA_PLAYLIST: {
                  	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
                  	command: "SPOTIFY_MA_PLAYLIST"
                  	SPOTIFY_TRANSFER: {
                  	pattern: "play the music on (.*)", // (.*)  is the name of your device
                  	command: "SPOTIFY_TRANSFER"
                            VOLUME_UP: {
                              pattern: "volume up",
                              command: "CMD_VOLUME_UP"
                            VOLUME_DOWN: {
                              pattern: "volume down",
                              command: "CMD_VOLUME_DOWN"
                            SET_VOLUME: {
                              pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                              command: "CMD_VOLUME_SET"
                          command: {
                            STOP_VID: {
                              moduleExec: {
                                module: ["MMM-AssistantMk2"],
                                exec: (module, params, key) => {
                                  module.assistant.subdom.youtube.innerHTML = "";
                                  module.assistant.subdom.youtube.style.display = "none";
                                  module.youtubePlaying = false;
                  	   SPOTIFY_TRANSFER: {
                  	    notificationExec: {
                                notification: "SPOTIFY_TRANSFER",
                  	         payload: (params) => {
                                   console.log("SPOTIFY_TRANSFER @",params)
                                  return params[1];
                             SPOTIFY_PAUSE: {
                              notificationExec: {
                                notification: "SPOTIFY_PAUSE"
                          SPOTIFY_PLAY: {
                              notificationExec: {
                                  notification: "SPOTIFY_PLAY"
                  	    notificationExec:  {
                  		notification: "SPOTIFY_PLAY",
                  		console.log("SPOTIFY_MA_PLAYLIST")
                  		return {
                  			context_uri:"spotify:playlist:0bdByehKVfdsfdsfdsOhF5t",   // Uri of a personnal playlist or album
                  		notification: "SPOTIFY_SHUFFLE",  // added this to toogle shuffle
                  		notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
                  	SPOTIFY_NEXT: {
                           notificationExec: {
                          SPOTIFY_PREVIOUS: {
                           notificationExec: {
                              notification: "SPOTIFY_PREVIOUS"
                          SPOTIFY_VOLUME: {
                           notificationExec: {
                             notification: "SPOTIFY_VOLUME",
                                   console.log("SPOTIFY_VOLUME @",params)
                                  return params[1];
                  	SPOTIFY_SEARCH: {
                           notificationExec: {
                             notification: "SPOTIFY_SEARCH",
                                  console.log("SPOTIFY_SEARCH @",params)
                                  return {
                                          type: "artist,track,album,playlist",
                                          query: params[1],
                                          random:false,
                           notificationExec: {
                                  console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                                  return {
                                          type: "playlist",
                                          query: params[1],
                                          random:true,
                            CMD_VOLUME_UP: {
                              notificationExec: {
                                notification: "VOLUME_UP"
                            CMD_VOLUME_DOWN: {
                              notificationExec: {
                                notification: "VOLUME_DOWN"
                            CMD_VOLUME_SET: {
                              notificationExec: {
                                notification: "VOLUME_SET",
                                payload: (params, key) => {
                                  console.log("@", params);
                                  return params[1];
                  exports.recipe = recipe // Don't remove this line.
                  This is the error
                  AMK2] Recipe is loaded: shutdown.js
                  /home/pi/MagicMirror/modules/MMM-AssistantMk2/recipes/spotify.js:183
                  SyntaxError: Unexpected token .
                      at new Script (vm.js:74:7)
                      at createScript (vm.js:246:10)
                      at Object.runInThisContext (vm.js:298:10)
                      at Module._compile (internal/modules/cjs/loader.js:678:28)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                      at Module.load (internal/modules/cjs/loader.js:620:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                      at Module.require (internal/modules/cjs/loader.js:658:17)
                      at require (internal/modules/cjs/helpers.js:20:18)
                  MagicMirror will not quit, but it might be a good idea to check why this happened.
                  ? 1 Reply Last reply
                    A Former User @Faiek
                    @Faiek
                    you might have missed closing brace somewhere. check to count opening and closung pairs.
                    F 1 Reply Last reply
                    • F
                      Faiek @Guest
                      @Sean Thanks for the response - i m lost - no programming knowledge whats so ever
                      trail and error got me thus far- and everything’s working great except spotify, still learning.
                      Can’t i get a completed (recipe.json) with any other require details, for voice activation on this module that could assist me, once i have one, ill probably be able to see my error.
                      Stomped for days now … online json checkers… really need to learn the basics …Thanks
                        @Faiek
                        Just add } over exports....
                        • F
                          Faiek @Guest
                          @Sean Thanks A Million - - working :grinning_face:
                          • I
                            Ivanov_d
                            @Sean I have changed the hook phrase to “showtime” and it still doesn’t work.
                            SPOTIFY_PLAY: {
                                pattern : "showtime",
                            [HOTWORD] Final Result: { detected: true, hotword: 'assistant', file: null }
                            [AMK2] assistant ready
                            [AMK2] Conversation starts.
                            [AMK2] Assistant Text Response:
                            [AMK2] Transcription: show  --- Done: false
                            [AMK2] Transcription: shut  --- Done: false
                            [AMK2] Transcription: showtime  --- Done: false
                            [AMK2] end-of-utterance
                            [AMK2] Transcription: showtime  --- Done: true
                            { requestId: '5d433446-0000-2772-8141-089e0827c3f4' } { profileFile: 'default.json', lang: 'en-US' }
                            [AMK2] Device Action: { requestId: '5d433446-0000-2772-8141-089e0827c3f4' }
                            [AMK2] Conversation Completed
                            null
                            [HOTWORD] begins.
                            [HOTWORD] Detector starts listening.
                              menanr
                                A Former User @menanr
                                @menanr
                                Check your firewall or network setting. And check also your MM is running on port 8888. You can try to connect “https://localhost:8888/callback” outside of your home network to check whether it is accessible from outside.
                                • T
                                  t.architecture99
                                  i can only see spotify logo and hear music . But nothing to show !!
                                  What can i do ? and how to config onStart: { ??
                                  Here is error logs
                                  [AMK2] Temporal storage directory is clearing.
                                  Whoops! There was an uncaught exception…
                                  TypeError: Cannot read property ‘getCurrentPlayback’ of null
                                  at Class.updatePulse (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:30:18)
                                  at Class.initAfterLoading (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:26:10)
                                  at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:44:12)
                                  at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                                  at Socket.emit (events.js:182:13)
                                  at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                                  at process._tickCallback (internal/process/next_tick.js:61:11)
                                    A Former User @t.architecture99
                                    @t-architecture99
                                    Maybe your ‘spotify.config.json’ would be wrong. Check it again.
                                      ricardoyen
                                      @brokenwings
                                      Hi did you figure this out, I’m stuck at this very same issue, I have Spotify working . how do I get voice assistant to integrate, do I modify the config.js file or the AssistantMK2.json file…??
                                        bminer1
                                        Having an issue with the song info showing up on the MM.
                                        I have everything installed correctly ( to my knowledge, or else it would work right?) and have the white Spotify symbol.
                                        I entered my Client ID and Secret.
                                        Callback and port are in there. I authorized through Spotify…
                                        Not sure what i am missing…
                                        Help?
                                          			module: "MMM-Spotify",
                                          			position: "bottom_left",
                                            				style: "mini", // "default" or "mini" available
                                            				control: "default", //"default", "hidden" available
                                            				updateInterval: 1000,
                                            				onStart: null, // disable onStart feature with `null`
                                            				allowDevices: [], //If you want to limit devices to display info, use this.
                                            				// allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                                          "CLIENT_ID" : "xxxx",
                                          "CLIENT_SECRET" : "xxxx",
                                          "AUTH_DOMAIN" : "http://localhost",
                                          "AUTH_PATH" : "/callback",
                                          "AUTH_PORT" : "8888",
                                          "SCOPE" : "user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state",
                                          "TOKEN" : "./token.json"
                                          A Former User @bminer1
                                          @bminer1
                                          Tell me more details. What happens on MagicMirror when you activate your spotify app on your smartphone?
                                          B 1 Reply Last reply
                                            bminer1 @Guest
                                            @Sean i restarted the pi and my computer that is running the spotify. Everything is running and working as it should. buttons work, displays very well and its all good. Sorry, for the false alarm. noob moment.
                                            • 12
                                            • 13
                                            • 5 / 13
