    MMM-Spotify
    249 Posts 51 Posters 340.6k Views 54 Watching
    • I Offline
      Ivanov_d
      @Sean, I did some more testing and I can confirm that this is the only command that doesn’t work. Maybe I am not understanding it correctly.
      My expected results would be:
      1. Raspotify is running in the background (but no music is playing)
      2. When I say “music please” spotify will start a random song and play it on the MagicMirror
      The result however is:
      1. Raspotify is running in the background and no music is playing
      2. When I say “music please” I see no errors in the logs, however, no music is starting as well
      3. To workaround this I start the music from my smartphone or desktop app and switch the player to MagicMirror, after that I can control the player via AssistankMK2
        [[global:former-user]] @Ivanov_d
        @Ivanov_d
        There could be 2(or 3)kinds of possibility about your issue;
        1. AssistantMk2 cannot catch your word “music please”
        2. AssistantMk2 could catch “music please” but cannot emit “SPOTIFY_PLAY” notification
        3. Spotify cannot receive (or understand) SPOTIFY_PLAY notification. (hmmm… I can’t agree about this)
        Well, I’ll test from last third issue. Wait for a while.
          @Ivanov_d
          I just tested 3rd case, and there is no problem to work. I think your music please phrase is not hooked, because music is reserved word for default Music feature of Assistant itself(for Youtube Music or Spotify on Google Home itself, but not yet supported by SDK for devices - only allowed for Google Home or some genuine devices). Some keywords or phrases are reserved for Google itself. Unless you override the keywords by Custom Action for Assistant (And even though, cannot guarantee it will work), your music keyword couldn’t work.
          Can you try other phrase? like “stay tune.” or any phrase you like.
          • I Offline
            Ivanov_d
            @Sean I will try that and report back. Thanks for the suggestion.
            • F Offline
              Faiek
              Hi Guys need some help with this module - newbie :smirking_face:
              I have the following loaded succesfully:
              AssistantMk2
              Hotword
              Raspotify
              Change device name in Raspotify :to Mirror
              Created a spotify.json - recipe(code from here) in recipes file this is it:
              Added the recipe to the Mk2.js
              recipes:[“hide_and_show_all_modules.js”, “reboot.js”, “screen_onoff.js”, “shutdown.js”, “spotify.js”],
              Dont know what i missed - any assistance please …
              var recipe = {
              transcriptionHook: {
                        STOP_PLAY: {
                          pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                          command: "STOP_VID"
                       // STOP_PLAY2: {
                       //   pattern: "arrête la musique",
                       //   command: "STOP_VID"
              	 SPOTIFY_PREVIOUS: {
                      pattern: "previous song",
                      command: "SPOTIFY_PREVIOUS"
                      SPOTIFY_PAUSE: {
                      pattern : "stop the musique",
                      command: "SPOTIFY_PAUSE"
                      SPOTIFY_PLAY: {
                      pattern : "music please",
                      command: "SPOTIFY_PLAY"
                      SPOTIFY_NEXT: {
                      pattern: "next song",
                      command: "SPOTIFY_NEXT"
                      SPOTIFY_VOLUME: {
                      pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                      command: "SPOTIFY_VOLUME"
                      SPOTIFY_SEARCH: {
                      pattern: "play (.*) on Spotify",
                      command: "SPOTIFY_SEARCH"
              	SPOTIFY_SEARCH_PLAYLIST: {
                      pattern: "playlist (.*) on Spotify",
                      command: "SPOTIFY_SEARCH_PLAYLIST"
              	SPOTIFY_MA_PLAYLIST: {
              	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
              	command: "SPOTIFY_MA_PLAYLIST"
              	SPOTIFY_TRANSFER: {
              	pattern: "play the music on (.*)", // (.*)  is the name of your device
              	command: "SPOTIFY_TRANSFER"
                        VOLUME_UP: {
                          pattern: "volume up",
                          command: "CMD_VOLUME_UP"
                        VOLUME_DOWN: {
                          pattern: "volume down",
                          command: "CMD_VOLUME_DOWN"
                        SET_VOLUME: {
                          pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                          command: "CMD_VOLUME_SET"
                      command: {
                        STOP_VID: {
                          moduleExec: {
                            module: ["MMM-AssistantMk2"],
                            exec: (module, params, key) => {
                              module.assistant.subdom.youtube.innerHTML = "";
                              module.assistant.subdom.youtube.style.display = "none";
                              module.youtubePlaying = false;
              	   SPOTIFY_TRANSFER: {
              	    notificationExec: {
                            notification: "SPOTIFY_TRANSFER",
              	         payload: (params) => {
                               console.log("SPOTIFY_TRANSFER @",params)
                              return params[1];
                         SPOTIFY_PAUSE: {
                          notificationExec: {
                            notification: "SPOTIFY_PAUSE"
                      SPOTIFY_PLAY: {
                          notificationExec: {
                              notification: "SPOTIFY_PLAY"
              	    notificationExec:  {
              		notification: "SPOTIFY_PLAY",
              		console.log("SPOTIFY_MA_PLAYLIST")
              		return {
              			context_uri:"spotify:playlist:0bdByehKVfdsfdsfdsOhF5t",   // Uri of a personnal playlist or album
              		notification: "SPOTIFY_SHUFFLE",  // added this to toogle shuffle
              		notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
              	SPOTIFY_NEXT: {
                       notificationExec: {
                      SPOTIFY_PREVIOUS: {
                       notificationExec: {
                          notification: "SPOTIFY_PREVIOUS"
                      SPOTIFY_VOLUME: {
                       notificationExec: {
                         notification: "SPOTIFY_VOLUME",
                               console.log("SPOTIFY_VOLUME @",params)
                              return params[1];
              	SPOTIFY_SEARCH: {
                       notificationExec: {
                         notification: "SPOTIFY_SEARCH",
                              console.log("SPOTIFY_SEARCH @",params)
                              return {
                                      type: "artist,track,album,playlist",
                                      query: params[1],
                                      random:false,
                       notificationExec: {
                              console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                              return {
                                      type: "playlist",
                                      query: params[1],
                                      random:true,
                        CMD_VOLUME_UP: {
                          notificationExec: {
                            notification: "VOLUME_UP"
                        CMD_VOLUME_DOWN: {
                          notificationExec: {
                            notification: "VOLUME_DOWN"
                        CMD_VOLUME_SET: {
                          notificationExec: {
                            notification: "VOLUME_SET",
                            payload: (params, key) => {
                              console.log("@", params);
                              return params[1];
              exports.recipe = recipe // Don't remove this line.
              This is the error
              AMK2] Recipe is loaded: shutdown.js
              /home/pi/MagicMirror/modules/MMM-AssistantMk2/recipes/spotify.js:183
              SyntaxError: Unexpected token .
                  at new Script (vm.js:74:7)
                  at createScript (vm.js:246:10)
                  at Object.runInThisContext (vm.js:298:10)
                  at Module._compile (internal/modules/cjs/loader.js:678:28)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                  at Module.load (internal/modules/cjs/loader.js:620:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                  at Module.require (internal/modules/cjs/loader.js:658:17)
                  at require (internal/modules/cjs/helpers.js:20:18)
              MagicMirror will not quit, but it might be a good idea to check why this happened.
                [[global:former-user]] @Faiek
                @Faiek
                you might have missed closing brace somewhere. check to count opening and closung pairs.
                • F Offline
                  Faiek @Guest
                  @Sean Thanks for the response - i m lost - no programming knowledge whats so ever
                  trail and error got me thus far- and everything’s working great except spotify, still learning.
                  Can’t i get a completed (recipe.json) with any other require details, for voice activation on this module that could assist me, once i have one, ill probably be able to see my error.
                  Stomped for days now … online json checkers… really need to learn the basics …Thanks
                    @Faiek
                    Just add } over exports....
                    • F Offline
                      Faiek @Guest
                      @Sean Thanks A Million - - working :grinning_face:
                      • I Offline
                        Ivanov_d
                        @Sean I have changed the hook phrase to “showtime” and it still doesn’t work.
                        SPOTIFY_PLAY: {
                            pattern : "showtime",
                        [HOTWORD] Final Result: { detected: true, hotword: 'assistant', file: null }
                        [AMK2] assistant ready
                        [AMK2] Conversation starts.
                        [AMK2] Assistant Text Response:
                        [AMK2] Transcription: show  --- Done: false
                        [AMK2] Transcription: shut  --- Done: false
                        [AMK2] Transcription: showtime  --- Done: false
                        [AMK2] end-of-utterance
                        [AMK2] Transcription: showtime  --- Done: true
                        { requestId: '5d433446-0000-2772-8141-089e0827c3f4' } { profileFile: 'default.json', lang: 'en-US' }
                        [AMK2] Device Action: { requestId: '5d433446-0000-2772-8141-089e0827c3f4' }
                        [AMK2] Conversation Completed
                        null
                        [HOTWORD] begins.
                        [HOTWORD] Detector starts listening.
                          menanr
                            [[global:former-user]] @menanr
                            @menanr
                            Check your firewall or network setting. And check also your MM is running on port 8888. You can try to connect “https://localhost:8888/callback” outside of your home network to check whether it is accessible from outside.
                            • T Offline
                              t.architecture99
                              i can only see spotify logo and hear music . But nothing to show !!
                              What can i do ? and how to config onStart: { ??
                              Here is error logs
                              [AMK2] Temporal storage directory is clearing.
                              Whoops! There was an uncaught exception…
                              TypeError: Cannot read property ‘getCurrentPlayback’ of null
                              at Class.updatePulse (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:30:18)
                              at Class.initAfterLoading (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:26:10)
                              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:44:12)
                              at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                              at Socket.emit (events.js:182:13)
                              at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                              at process._tickCallback (internal/process/next_tick.js:61:11)
                                [[global:former-user]] @t.architecture99
                                @t-architecture99
                                Maybe your ‘spotify.config.json’ would be wrong. Check it again.
                                  ricardoyen
                                  @brokenwings
                                  Hi did you figure this out, I’m stuck at this very same issue, I have Spotify working . how do I get voice assistant to integrate, do I modify the config.js file or the AssistantMK2.json file…??
                                    bminer1
                                    Having an issue with the song info showing up on the MM.
                                    I have everything installed correctly ( to my knowledge, or else it would work right?) and have the white Spotify symbol.
                                    I entered my Client ID and Secret.
                                    Callback and port are in there. I authorized through Spotify…
                                    Not sure what i am missing…
                                    Help?
                                      			module: "MMM-Spotify",
                                      			position: "bottom_left",
                                        				style: "mini", // "default" or "mini" available
                                        				control: "default", //"default", "hidden" available
                                        				updateInterval: 1000,
                                        				onStart: null, // disable onStart feature with `null`
                                        				allowDevices: [], //If you want to limit devices to display info, use this.
                                        				// allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                                      "CLIENT_ID" : "xxxx",
                                      "CLIENT_SECRET" : "xxxx",
                                      "AUTH_DOMAIN" : "http://localhost",
                                      "AUTH_PATH" : "/callback",
                                      "AUTH_PORT" : "8888",
                                      "SCOPE" : "user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state",
                                      "TOKEN" : "./token.json"
                                      [[global:former-user]] @bminer1
                                      @bminer1
                                      Tell me more details. What happens on MagicMirror when you activate your spotify app on your smartphone?
                                        bminer1 @Guest
                                        @Sean i restarted the pi and my computer that is running the spotify. Everything is running and working as it should. buttons work, displays very well and its all good. Sorry, for the false alarm. noob moment.
                                          matt216
                                          Love the module, but noticed it makes the mirror by far the noisiest device on my network. Any idea why it talks so much to the spotify api?
                                            [[global:former-user]] @matt216
                                            @matt216
                                            Because, Spotify playback API doesn’t be designed to push the status to the caller. The module should use pooling to get CURRENT playback status whenever it is needed. Set bigger value to updateInterval.
                                            • 12
                                            • 13
                                            • 6 / 13
