    Problems with starting pm2 start mm.sh
    27 Posts 7 Posters 17.8k Views 7 Watching
    • G Offline
      Gomalley
      And I tried restarting the pi and the “Booting up” MagicMirror2 showed but it never actually loaded.
        sdetweil @Gomalley
        @Gomalley ok
        pm2 list
        If nothing
        pm2 start installers/mm.sh
        pm2 save
          Detto65 @madoXX
          @madoXX
          just did a fresh install of my magicmirror, because the sd card went corrupt.
          during the install procedure it somehwere asked me if i want to autostart MagicMirror.
          after that it started automatically after booting into the desktop first.
          When trying to use pm2, it shows me the process is already running, but it’s name is MagicMirror , not mm.
          MagicMirror version 2.8.0
            sdetweil @Detto65
            @Detto65 yes, the install script uses a json file to configure the pm2 process
            • G Offline
              Gomalley
              When i do
              pm2 list
              The "name, id, mode, status, cpu, and memory chart shows up. It is all in blue.
              Below it, it says “use ‘pm2 show <id/name>~ to get more details about an app.’”
              When i type in
              pm2 start
              The same chart above displays along with a message saying
              [PM2] [ERROR] File ecosystem.config.js is not found
              What does this mean?
                Raksasas
                I am having the same problem: I did what was mentioned above and after the reboot it stll did not start automaticly. Running “pm2 list” after the reboot shows mm.sh is not runnning.
                permitted by applicable law.
                Last login: Sun Jul 28 20:48:49 2019
                pi@magicmirror:~ $ pm2 list
                [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                [PM2] PM2 Successfully daemonized
                │ App name │ id │ version │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ user │ watching │
                 Use `pm2 show <id|name>` to get more details about an app
                pi@magicmirror:~ $ pm2 start installers/mm.sh
                [PM2][ERROR] script not found : /home/pi/installers/mm.sh
                pi@magicmirror:~ $ pm2 start mm.sh
                [PM2] Starting /home/pi/mm.sh in fork_mode (1 instance)
                [PM2] Done.
                │ mm       │ 0  │ N/A     │ fork │ 718 │ online │ 0       │ 0s     │ 0%  │ 2.6 MB   │ pi   │ disabled │
                pi@magicmirror:~ $ pm2 save
                [PM2] Saving current process list...
                [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                │ mm       │ 0  │ N/A     │ fork │ 718 │ online │ 0       │ 44s    │ 0%  │ 2.6 MB   │ pi   │ disabled │
                pi@magicmirror:~ $ sudo reboot
                Connection to 192.168.138.28 closed by remote host.
                Connection to 192.168.138.28 closed.
                pi@magicmirror:~ $ cat mm.sh
                cd /home/pi/MagicMirror
                DISPLAY=:0 npm start
                pi@magicmirror:~ $ ls -lha mm.sh
                -rwxr-xr-x 1 pi pi 45 Jul 28 20:14 mm.sh
                pi@magicmirror:~ $
                  sdetweil @Raksasas
                  @Raksasas should be executing those while in the MagicMirror folder
                    Raksasas @sdetweil
                    Looking over the “Auto Start” page I do not see where it states that the pm2 commands are to be run while inside the MagicMirror folder.
                    With you stating that it seems to be saying that the “mm.sh” script needs to be ran from inside the “MagicMirror” too. Again the “Auto Start” page shows that it was created inside the ‘home’ (~) folder. So one would think/presume it can be ran from inside the “home” folder also.
                    Either way I will give it a go.
                    mumblebajM S 2 Replies Last reply Reply Quote 0
                    • mumblebajM Offline
                      mumblebaj Module Developer @Raksasas
                      @Raksasas My mm.sh resides in my /pi/ folder and not in the MagicMirror folder so should work. It might be that there was an error while you were setting up pm2 or setting up the autostart perhaps?
                        sdetweil @Raksasas
                        @Raksasas it was the
                        That needed to be done from the MagicMirror folder.
                        Cause I ‘ASSUMED’ if u were working on mm, you would always be in that folder.
                        installers folder is in mm, not in user home
                          Raksasas
                          Part 1:
                          Just tried the
                          pm2 save
                          From within the “MagicMirror” folder and no change. MagicMirror starts and at reboot it does not automaticly start
                          See below for my fix
                          Part 2:
                          @mumblebaj
                          This seems possible. So i re-ran
                          sudo npm install -g pm2
                          pm2 startup
                          After running “pm2 startup” this time I noticed the following:
                          To setup the Startup Script, copy/paste the following command:
                          sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                          So I ran that and followed with the “pm2 start mm.sh” and “pm2 save”. Well now it is auto starting on reboot.
                          S mumblebajM 2 Replies Last reply Reply Quote 0
                            sdetweil @Raksasas
                            @Raksasas great news!
                              @Raksasas Exellent. Great it is working now.
                              • T TDMPro2K referenced this topic on
